February 12, 2026, 05:01:53 AM
No dash lights, no crank, but battery is good.
Topic: No dash lights, no crank, but battery is good. (Read 1418 times)
Boxcar01
April 05, 2022, 07:32:23 PM »
This just happened today. Put the key in and turned it lights came on as normal when I hit the starter there was a few quick ticks than nothing. The dash lights did not light up anymore. The battery appears to be good, the charger says 14.2 V and 0.23 Amps.
So right now nothing at all happens when the key is turned, no lights on the dashboard, no anything. Has anyone experienced something similar and if so what was the culprit? Thank you very much
RonW
Newport Beach
Re: No dash lights, no crank, but battery is good.
April 05, 2022, 07:39:15 PM »
Did you check the fuse in the starter relay?
Last Edit: April 05, 2022, 07:41:18 PM by RonW
2000 Valkyrie Tourer
dizzy
April 06, 2022, 04:57:32 AM »
Make sure battery terminals are tight.
April 06, 2022, 05:31:33 AM »
Dirty (or deformed) starter switch is a common problem.
There's probably a thousand posts on it here. (some with DIY pics)
Tiny little parts.
jnicks01
Clinton, IN
April 06, 2022, 05:58:39 AM »
Still sounds like a battery to me seeing you had "clicks". What does your multimeter say? Not the charger. What are your volts when cranking?
I want to scoop out your brains and eat your knowledge.
Boxcar01
April 06, 2022, 10:42:21 AM »
Quote from: dizzy on April 06, 2022, 04:57:32 AM
Yep, that did it, tightened up the battery terminals and everything is back to normal. Thanks all
