February 12, 2026, 05:00:20 AM *
Author Topic: rear wheel dampers  (Read 1408 times)
6adan
Zip City, Alabama
« on: April 08, 2022, 12:02:05 PM »
 I have the rear wheel off for a tire change and service. The dampers have some back and forth looseness in them. Should there be any play be in dampers?
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
pancho
Bonanza Arkansas
« Reply #1 on: April 08, 2022, 01:30:57 PM »
Get yourself some new ones, you will appreciate how smooth the bike will feel. The less play in the drive train, the smoother it will be.
« Last Edit: April 08, 2022, 01:33:21 PM by pancho » Logged
« Reply #2 on: April 08, 2022, 01:33:42 PM »
Buy the all in one units for an I/S if you have a standard or tourer. Cheaper.
« Reply #3 on: April 08, 2022, 04:02:19 PM »
I believe the all-in-one dampers for interstate have now superseded the original parts for standard and tourer, which were in two parts (the rubbers and the grommets separate).
If yours are still in good shape and not crumbling, some have shoved strips or rubber inner tube in them to snug them up, but I'd rather have new.  Also, make sure to get the cover plate on correctly (upside down is wrong).
