February 12, 2026, 05:01:38 AM
Old Alternator
Topic: Old Alternator (Read 1577 times)
DIGGER
Old Alternator
April 11, 2022, 04:39:20 AM »
My Valkyrie’s alternator went out at 75,000 miles. I had it replaced. I still have the old one. Being a high dollar item is it worth taking it somewhere to be repaired to keep as a spare or best to chunk it?
da prez
Wilmot Wi
Re: Old Alternator
April 11, 2022, 06:17:56 AM »
Have it tested. If the field is shorted , the repair cost is to high last time I checked. There is a post in tech about a high output alternator .
da prez
Earl43P
Farmington, PA
Re: Old Alternator
April 11, 2022, 11:26:06 AM »
Installing new brushes is fairly easy and inexpensive, if that’s the problem.
I would disassemble it enough to check them.
I replaced my brushes at 96k miles and put it right back in service.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Re: Old Alternator
April 11, 2022, 05:40:57 PM »
It is easy enough to take apart and using the Service Manual test it.
There are posts in the forum on how to fix it. As said, brushes are very easy to do.
Avanti
Stoughton, Wisconsin
Re: Old Alternator
April 11, 2022, 05:50:58 PM »
Does anyone know the part numbers for front and rear bearing numbers.
Re: Old Alternator
April 11, 2022, 06:04:57 PM »
I found this post,
http://www.valkyrieforum.com/bbs/index.php/topic,73080.0.html
Second one has the bearing/seal #'s.
Avanti
Re: Old Alternator
Reply #6 on:
April 11, 2022, 07:11:08 PM »
Quote from: gordonv on April 11, 2022, 06:04:57 PM
I found this post,
Thank you
