March 22, 2026, 06:57:05 PM *
Author Topic: oil thread to stir up the Valkyrie members  (Read 1252 times)
LTD
« on: April 12, 2022, 03:01:58 PM »
I have gone back to a honda oem filter and honda 10w40 oil . I use to use rotella 5w40 and a mobil 1 110 car filter. But jersey98 i believe said they changed theformula on the rotella no longer valkyrie friendly.  am I one of the few using oem filters and 10w40 honda oil?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: April 12, 2022, 03:13:12 PM »
I'm not sure about the filters (I use CarQuest filters @ $2.99 each by the case), but Honda does NOT make oil.
« Reply #2 on: April 12, 2022, 03:56:09 PM »
There are many perfectly acceptable MC oils for our use. Spectro makes very good MC products. As long as you use oil spec’s for MC use, you’re good. My oil filter choice is a Purolator Boss (PBL14610) which I have to get from Amazon. Pep Boys handled them but have shutdown their retail stores here.
« Reply #3 on: April 12, 2022, 04:22:37 PM »
Well I know because Im old enough to remember the oil threads of the past. So not to stir up anything but I use mobile one m/c oil. Even though it says VTwin on it. Im sure it will lube 6. Im bearing down on 200,000 miles and my oil is still so clean if I try to check it on the dip stick (I almost never do) it’s hard to see.  The bike runs like new. You can’t ask for more from an oil. Honda oil can’t be twice as good just because it costs twice as much. My .02
« Reply #4 on: April 12, 2022, 05:05:29 PM »
Probably yes.
Just so you know Honda does not refine oil and I seriously doubt that Honda manufacturers oil filters.  They have someone else put Honda's name on some of their product.
I've hundreds of thousands of miles on Valkyries.  I don't remember ever using an oil or filter with Honda's name on it.
Honda makes motorcycles.  I want the Honda name on all my motorcycles.
« Reply #5 on: April 12, 2022, 08:18:44 PM »
Probably yes.
Johnson Controls makes filters for a bunch of companies so, I suspect you're correct.   So does Wix.
Reference oil, pick your poison.   I got a heck of a deal on some oil a while back when it mistakenly was put on clearance.  Bought all I could get.  May never have to buy motorcycle oil again.  Cheesy
Royal Purple at $2.95 a quart, couldn't pass that up.
« Last Edit: April 13, 2022, 05:47:18 PM by Rams » Logged
h13man
Indiana NW Central Flatlands
« Reply #6 on: April 13, 2022, 07:21:29 AM »
Had issues with the new formulated T6 also. Running Mobil1 & Bosch #3323 long filter. Been using Bosch filters for about 10 yrs.
« Reply #7 on: April 13, 2022, 07:45:01 AM »
One voice in the cacophony:
OEM Honda branded oil filters and Mobil 1 15w50 oil.
« Reply #8 on: April 13, 2022, 10:23:40 AM »
what changed i n the formula and when
I have a bunch in my basement all at least a few years old
six2go #152
Ft. Wayne, IN
« Reply #9 on: April 13, 2022, 11:28:41 AM »
Can't tell ya when, Oss, but if I remember correctly the amount of Zinc was reduced in the new formula which some said made it less friendly to MC engines with wet clutches. I've never used the stuff but it seems like that was the issue.(if it really is an issue)
suthrncop
mobile, AL
« Reply #10 on: April 13, 2022, 01:53:16 PM »
Does anyone use Redline oil, that’s all I can find around here in 10w30 synthetic (2014 Valk)right now
six2go #152
Ft. Wayne, IN
« Reply #11 on: April 13, 2022, 04:30:40 PM »
Do you have O'reillys stores where you are? I get Lucas Synthetic 10w-30 there for my F6B. The 1832cc flat 6 really likes it.
« Reply #12 on: April 13, 2022, 08:54:18 PM »
a good cheap oil filter is made by HI-FLO comes in black for around 8 bucks each.  Either that or Purolator as said prior.
I think was HF303 if not mistaken.  My UTV/ATV store nearby had them for 7.95 each so bought the last 3 they had but called another cycle store and were 10 bucks each so maybe price is going up like everything else is?
sucks as well I see my local Farm Fleet not carrying rotella T6 as well anymore.  I asked them and they claim is a shortage of Shell supplying them with product.  Hard to beat their pricing on sale under 20 bucks for 1 gallon jug and under 40 for 2.5 gallon jug.
I quit using Amsoil 10w-40 full synthetic once it went over 11 bucks per quart now 12-13 per qt.  Just too costly when have 4-5 cycles using it to change yearly.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #13 on: April 13, 2022, 09:00:13 PM »
I pay about $40/gallon for Amsoil motorcycle oil.
« Reply #14 on: April 13, 2022, 09:06:39 PM »
where do you get it still for 10 bucks per quart?
luftkoph
E U.P. Mich
« Reply #15 on: April 14, 2022, 04:42:41 AM »
Supertech full syn 10-40 motorcycle oil, with a honda filter, jeez its an under-stressed Honda motor, it would probably work with bacon grease in the sump. Evil
Some day never comes
« Reply #16 on: April 14, 2022, 05:41:33 AM »
^^this^^  cooldude
I used Honda oil for years in my 1500 because it was so easy to mash the "send me
a box full" on the HDL Valkyrie specific web page.
More recently, with two bikes, I've been running synthetic oil. I haven't found any
mobil-1 oil (just that two cylinder stuff Jeff runs  Wink  ) anywhere, locally or on line, so
I got a few boxes of Castrol synthetic motorcycle oil. Anyone remember the wonderful
smell of Castrol bean oil at the motocross track?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #17 on: April 14, 2022, 06:42:57 AM »
I buy straight from Amsoil, but I buy the one gallon jugs. Quarts are more.
h13man
« Reply #18 on: April 14, 2022, 07:19:19 AM »
EPA mandate was changed in 2017. The spring of 2019 was when I had the issue after buying a new formula jug. Now's that assuming my memory is a workin' proper.  Undecided
Ramie
2001 I/S St. Michael MN
« Reply #19 on: April 14, 2022, 07:31:47 AM »
^^this^^  cooldude
I remember the smell of bulk oil my dad sold in his gas station 60 years ago.  Had to pump into a big glass container with a metal spout on it.  The farmers always bought it because it was cheaper than the stuff in the can's.
« Reply #20 on: April 14, 2022, 07:48:27 AM »
I just checked, and my local Wal-Mart has Mobil 1 15w50 in stock for $27.47 for a 5 quart jug.....
Just saying...
https://www.walmart.com/ip/Mobil-1-Advanced-Full-Synthetic-Motor-Oil-15W-50-5-Quart/20713647
Avanti
Stoughton, Wisconsin
« Reply #21 on: April 14, 2022, 08:29:46 AM »
I thought Mobile 1 VTwin oil used friction modifiers.
« Last Edit: April 14, 2022, 08:32:32 AM by Avanti » Logged
luftkoph
E U.P. Mich
« Reply #22 on: April 14, 2022, 07:47:19 PM »
^^this^^  cooldude
I mix a little Klotz techniplate in my lawn mower, love the smell.
