February 12, 2026, 07:05:50 AM *
Author Topic: FORK OIL?  (Read 1817 times)
Twofeather
Benton, Arkansas
« on: April 21, 2022, 07:09:27 AM »
Is there a way to check and or fill forks without taking them off the bike?
I just recently replace fork seals on my fat lady. I did as directed from my book and put in the recommend oil amount in each fork. The bike does not feel right. When Appling the brakes the front dips a little. I'm thinking I need to add some fork oil. I'd like to check and see if I'm low on oil. What do you guys think?
FROM MY DEAD COLD HANDS
Bagger John - #3785
« Reply #1 on: April 21, 2022, 09:10:16 AM »
You can remove the fork caps and use a measuring rod to check the level.
Have the forks ever been serviced/taken apart? If so, which weight of fork oil was put back in?
Twofeather
Benton, Arkansas
« Reply #2 on: April 21, 2022, 09:52:43 AM »
10 wt oil is the oil I used after I rebuilded both forks. I measured the oil out according to the book, but I don't think it is right. The bike handles ok in the corners it just doesn't feel right and it dip a little when I get on the front brakes. So, I'm thinking I need to add some oil.
« Reply #3 on: April 21, 2022, 10:19:33 AM »
Fork oil can be measured by quantity (ozs) or by depth.  It's my understanding they are not supposed to be entirely equal.
Twofeather
Benton, Arkansas
« Reply #4 on: April 21, 2022, 10:51:32 AM »
Each fork had a different measurement, but I think it is wrong.
I read on here I think that you have to compress the forks to measure the depth?  Is that right?
h13man
Indiana NW Central Flatlands
« Reply #5 on: April 23, 2022, 05:19:43 AM »
Each leg is different volume for sure. The dipping is the norm for OEM springs due to being "soft" from the factory. Progressive makes a good replacement spring and Racetech makes different strength of springs for different weights applications. Me @ 165-185 lbs. with heavy loads, the #80 springs work really well but it took some time to break in. The previous owner didn't like them because of them being too stiff. 10w Belray fork oil is my preference and is the most popular brand to find locally or online.
 https://racetech.com/ProductSearch/12/Honda/GL1500C%20Valkyrie/1999
RonW
Newport Beach
« Reply #6 on: April 24, 2022, 07:10:48 AM »
do you think the old oil was 15w?
2000 Valkyrie Tourer
Twofeather
Benton, Arkansas
« Reply #7 on: April 30, 2022, 08:47:52 AM »
Ron, I talked with the p.o. and he said he used 10 wt. Oil. So that is what I used. I added another 50 cc of oil and seemed to help but I still think it needs more. I'm not real sure how to measure from the top down with the forks on the bike. I'm thinking of adding some more oil till it feels and rides good. Is that thinking wrong?
RonW
Newport Beach
« Reply #8 on: April 30, 2022, 09:23:41 AM »
"I'm not real sure how to measure from the top down with the forks on the bike."
me too. Agreed, just keep adding more oil by increments and go by feel.
turtle254
Livingston,Texas
« Reply #9 on: April 30, 2022, 09:40:43 AM »
On the left side you can't pull oil back out, if you over fill. Right side by extending forks you can see the oil looking down.
