News:
Main Menu
Generic Parts List
Started by Hondasan, Mon 25, Apr 2022, 14:44:09
Previous topic - Next topic
Hondasan
Hi
Haven't been on the board a few years, riding my VStrom 650 more , but want to get my Valk in shape to ride use it more. Due for new timing belts, brake hoses Etc.
I lost my generic parts list ! (Was it Chet/rattlebars that published it ?)
The VRCC websites changed some, so maybe it is somewhere, but most searches go to dead links
2000 Valkyrie, added tourer bags, IS tank, too much Cobra chrome, kick shifter, drilled piggies...
Timbo1
#1
I copied a generic part list back in 2006 so in a word doc I could email you if you pm me your email.
ETA:  easier to just paste it here.  IDK how accurate or if there were any updates after I copied this.
Generic Parts
Wheel Bearings
1997 Front 6004-2RS
1998-2000
Front, 6204-2RS or  6204LL
And all models left rear 6204-2RS or  6204LL
(same bearing different mfg.) 6204 is size, letters indicate sealed both sides. See below about seal designation
1997-2000 All right rear  5204?? Double Row Angular Contact Bearing
They need to be sealed both sides.
MRC #5204ZZ
RSR #5204EE
IKS #52042RS
The list goes on, and on. Just get a 5204 that is sealed on both sides. Mfg's use different suffixes to designate seal configuration. The list would be as long as my arm. And if you ask for a 5204 2RS and the child behind the counter knows nothing about bearings, he may tell you they don't have it. But they do have 5204ZZ's. But that isn't what you asked for.
If you have a "bearing house" nearby go there and ask for a 5204 with seals on both sides, then keep a spare at home. They only cost about $11
   Timing Belts
Gates # 275
Napa # 250275
I paid $17.95 List is $30  But my Honda Stealer wanted $49.00
Wheel Seals
The right fronts differ in 97
some 97's took 28X42X8
and some took 28X47.2X7
Left front is 45X55X5
All the I/S models took 289X47.2X7 on the front right
And 45X55X5 on the speedo side
The rear is
30 x 47 x 8   Thermostat
I found the thermostat that is the automotive application that Honda must use. It has 160, 180 and 190 degree. The part #143-0687 this is a car quest number the application I ordered was for a 93 Mitsubishi montero with a 3000 engine v6. Its a direct fit. I put the 180 in the Valk and it works great more power and feels allot better in riding because it doesn't throw as much heat out. This is the same temp as the stock Honda thermostat but the temp is consistently lower. I am going to go with the 160 for summer. I think a 94 supra takes the same too
Contributed by Robert
Oil Filters
The following numbers have been verified.
Purolator ML 16817
Mobil 1 M1-110
The following numbers have not been tested by me, they were referred to me. I believe they all fit the bike but aftermarket chrome covers might not.
AMSOIL SDF-13
Fram PH 6017
STP S-02808
AC PF1127 or PF1051
LEE LF2808 or LF2808HP
Purolator L14459
Wix 51334
GM 94149418
Mazda N231-23-802
Mitsubishi MD097003
Motorcraft FL810
K&N oil filter KN-303 Black
K&N oil filter KN-303C Chrome
Emgo
Paper element 10-82220
Microglass Element 10-82222
Both are chrome
Emgo 10-82230 is black and the Cobra chrome cover will fit.
Amsoil
SMF-103
SMF-103C (Chrome)
Wal-Mart ST
filters are made by Champion Labs who also make STP, Bosch and Mobil-1 filters.
ST6607 52 sq in of media. same size as OEM
ST7317 62 sq in media same dia 1/2 longer then OEM
ST3593A (160 sq in? not confirmed) larger dia but shorter than ST3717
all of the above have the required 8-11 psi by-pass valve.
   Supercharger Related Parts
Belt
040315 or 040320
I use the 040320 it's longer and gives more pulley wrap.
Idler Pulley Bearing
6203 V
6203 ZZ
Upper radiator hose.
(B) 71260
Tube to manifold O-rings
Tube to head O-rings
Dash 123
   Tach and Speedo bulbs for Non- Interstate Valks
Wagner Lighting p/n 193
bulb 4.6w,14v,15,000hr
perfect illumination & LONG LIFE....for about .60cents ea;
couple of ph #s....Federal-Mogul/Wagner Lighting....800-537-8984;
Parts Plus (one distributor) 800-727-8112  (other manufacturers' hour life rating can be less/half....7500hrs) #193 is the industry lookup standard
Mark (Valkrocket in Utah)
If you know of a generic part that should be included on this page let me know.   mailto:Jeff K
Alternator Options
'97 Goldwing Aspencade
Part # is 31100-MT2-015
"The terminal & plastic insulator are different where you connect the alternator battery wire. You have to take off the capacitor that is mounted on the Gold Wing alternator and rotate the front housing to match the holes from the Valkyrie model so that it will fit."
Spark plugs
NGK_P/N = DPR7EA-9
ACCEL = 882
AC_DELCO = R121XLS
AUTOLITE = 4164
BOSCH = XR4CS
CHAMP = RA6HC
GM_NUMBER = 5614066
MOTORCRAFT = 87
MTRCFSTK = HG2C
PRESTOLITE = 12G2,12G3
NGK MODEL = STD
SEAT TYPE = GASKET
THREAD SIZE = 12MM
REACH = .750
HEX_SIZE = 18MM
   Valkyrie Interstate Driving Light Relay
AutoZone sells a Pilot (brand) Replacement Relay for $4.99
The Pilot relay model number on the packaging card is PL-RY1.
Note: Number C0249 is printed on the relay itself.
Also
Interstate - (Hondaline Driving lites), and found that a Fog lite Relay from
a Honda CR-V # 39797-SE0-004 is exactly the same
Inserts for fairing, Honda part #
90316-MJ1-000
Interstate Dash bulbs
#74
Standard dash bulb, available at any auto parts store.
And there's this
https://www.jkozloski.com/generic_parts.htm
which I printed, laminated and carried in my saddlebag.
Timbo1
Thanks britman,
That looks like what I originally copied but with updates to what I had.  Now I have the updated version.
Hondasan
