February 12, 2026, 05:00:22 AM *
Author Topic: Poor Design  (Read 1925 times)
RIX97
« on: April 27, 2022, 04:03:10 PM »
I love Honda's, I've been riding them since 1967 and have always admired their ingenuity and quality but there is at least one idea on this current bike that is just plain dumb. I had to take the rear bottom section of the fender off my '98 Valk, easy enough to do, one screw on top and two more, one on each side. These are the two problem bolts when you're trying to put them back in place, they go through a chrome piece, through the upper part of the rear fender and then into the bottom fender with a nut supposedly help captive but that square nut slips down because of gravity. There is no access to the back of the nut so you can't move it in place. I've used some silicon to hold it in place, hopefully that works but what a poor design.
Savage
United States
« Reply #1 on: April 27, 2022, 04:18:34 PM »
I remedies this by replacing the front and rear bolts with metric threaded rod. Cut the square nut cage out of the fender, captured the threaded rod in the fender with bolts and washers inside and outside the fender. Now the saddlebags can also be removed whenever I want without dropping the fender - just removed a couple nuts and washers.
Columbia, South Carolina
RIX97
« Reply #2 on: April 27, 2022, 04:22:19 PM »
Good idea
« Reply #3 on: April 27, 2022, 06:29:52 PM »
Or you can simply reach under there and with a finger push the rectangular nut back up into place and get the bolt started. It’s really quite easy
h13man
Indiana NW Central Flatlands
« Reply #4 on: April 28, 2022, 05:16:24 AM »
That pretty much what I did but the silicone idea sounds good also.
RonW
Newport Beach
« Reply #5 on: April 28, 2022, 05:41:12 AM »
if memory serves, one method was to grab the rear fender    at 'X'   at A and finagle the fender back and forth to align the cage nut.
« Last Edit: April 29, 2022, 12:08:01 AM by RonW » Logged
2000 Valkyrie Tourer
« Reply #6 on: April 28, 2022, 02:12:10 PM »
I do that with my pants all the time.   Grin
six2go #152
Ft. Wayne, IN
« Reply #7 on: April 28, 2022, 02:19:13 PM »
But most Valkyries are "dirty" under there.  Roll Eyes
ridingron
Orlando
« Reply #8 on: April 28, 2022, 09:46:16 PM »
I doubt he's ever experienced that on his bike!   Grin
ridingron
Orlando
« Reply #9 on: April 28, 2022, 09:49:28 PM »
if memory serves, one method was to grab the rear fender at 'X' and finagle the fender back and forth to align the cage nut.
Wouldn't that be grab the fender at "A"?   Wink
RonW
Newport Beach
« Reply #10 on: April 29, 2022, 12:05:09 AM »
whoops
« Reply #11 on: April 29, 2022, 12:45:03 AM »
I never remove my fender.  To change the tire, lift the bike on a table lift, lift the back of the bike with a screw-platform jack using my mounted lift adapter, and lower the back wheel and swingarm after removing the shocks, with another screw-platform table jack under the tire.  I have a Hitchdoc trailer hitch but I do it this way with my other 2 Valks as well.  These are lifts I have anyway, very useful for other tasks but work well for this.
HappyTrails
Aurora Colorado
« Reply #12 on: April 29, 2022, 05:10:59 PM »
Did that the other day after experimenting removing the sidebags. 5min to tale off the brackets, 30min to put back in place lol
"I would rather see this world through the eyes of a child" ~ Aurora
