March 22, 2026, 12:56:20 PM *
Author Topic: I hate  (Read 1344 times)
« on: May 03, 2022, 12:56:24 PM »
getting defeated.
We are headed to Alaska in a few weeks in our motorhome. It wasn’t running well at all the last couple times I drove it. The gas had been in it for years, so it seemed reasonable that I needed to siphon it out. I did and added 5 gallons of fresh fuel. Then I discovered the fuel pump went bad. Got a new one along with a new inline filter. Had to do all this in the gravel of our front yard as I couldn’t move it to the driveway. Wrangling a 50 gallon tank in the gravel is not easy. Especially when you are old and fat. Anyway, I get it all done and everything properly hooked up. Take it for a test run and it’s running really rough with black smoke poring out the tailpipe. Figure the old gas had probably clogged the injectors. Rebuild the throttle body unit with a kit and new injectors. Take it for another test run. Now it’s worse than ever !
After much brain wracking (not easy with a little brain) I rent a fuel pressure tester and find the fuel pump is putting out 60 psi when it should be about 12 psi. Run back to O’Reilly’s and find that their computer system is wrong, and has the same pump listed for a TBI and an MPI. Finally get the correct one and feel like I’m on the home stretch. At least now I have the motorhome parked in the driveway. I was feeling all giddy with excitement that I would soon have a smooth running engine. Nope ! It’s just as bad if not worse.
I’m at my wits end with it and have an appointment to have it towed to the shop Thursday. I HATE LOSING !
« Reply #1 on: May 03, 2022, 02:38:32 PM »
Wish I had an answer for you, but too many possibilities for me to offer any advise. But I just want you to know that I appreciate you doing your part to stimulate the economy. Have a safe trip To Alaska, I could be a tiny bit jealous. cooldude
msb
Agassiz, BC Canada
« Reply #2 on: May 03, 2022, 09:10:02 PM »
You'll hate driving it up through BC with a rough running engine a lot more,  with the price of our gas up here.
'99 Red  & Black IS
« Reply #3 on: May 03, 2022, 09:48:59 PM »
I’ve been trying to follow it for a while now. It does seem pretty high. But when you factor in the exchange rate it not quite so shocking. Although I figure our round trip is going to run us close to 6 grand just in gas. It is what it is. We have had enough of being hunkered down. Too many friends and family have passed lately. You can’t take it with you. I’m just glad we won’t have the hassle of testing to cross back and forth.
Hopefully the Ukrainians will continue kicking Putin’s butt and the oil prices will come back down.  Smiley
msb
Agassiz, BC Canada
« Reply #4 on: May 04, 2022, 07:25:43 AM »
You're right there....your US exchange will soften the blow for sure. You're also quite right in saying "screw it, I'm going regardless"...that's what life's for, eh?
What's your planned route up to the Alaska Hwy?
'99 Red  & Black IS
Wizzard
Bald River Falls
Valparaiso IN
« Reply #5 on: May 04, 2022, 07:40:20 AM »
Rob,
Good for you. Get it fixed and take off and enjoy. If you spend your last dime the day you leave this earth you have accomplished something. Good luck and post some pictures.  cooldude
« Last Edit: May 04, 2022, 11:00:05 AM by Wizzard » Logged
VRCC # 24157
« Reply #6 on: May 04, 2022, 08:08:06 AM »
Sometimes it's better to just take it tp the pros. On a trip like that, you definately want a properly running engine that won't konk out on you.
(envious) have a good trip.
« Reply #7 on: May 04, 2022, 09:17:12 AM »
Probably just going to take the quickest, direct route thru Calgary, Edmonton on the way up. Need to be at my brothers service June 11. Coming back I hope to take the Cassiar and thru B.C.
« Reply #8 on: May 04, 2022, 09:40:20 AM »
Rob,
Your plans appear to this adventurer to have all the trappings of a serious adventure just ahead! I hope you and Brenda (Brayden going with y'all?) enjoy yourselves, and I trust you will keep us informed of all your experiences... This just could become an epic journey, ya know?!!! My best wishes for a safe and wonderful trek...
« Reply #9 on: May 04, 2022, 10:12:57 AM »
Rob,
Thanks, Bruce  cooldude yeah Brayden and my granddaughter Shaelyn will be going with us.
« Reply #10 on: May 04, 2022, 11:33:44 AM »
Rob,
Thanks, Randy. My plan is to spend every last penny before I die.  Smiley
