February 12, 2026, 07:05:46 AM *
Author Topic: Fuel line disconnect  (Read 1743 times)
MotoBob
« on: May 11, 2022, 04:08:30 AM »
Does anyone know the part number for the Colder Products fuel line disconnect that Red Eye advertises there replacement O rings for?
« Reply #1 on: May 11, 2022, 05:30:02 AM »
I bought a bike that had one installed. Didn’t like it. You can have it for shipping
Pm your address if you want it
« Reply #2 on: May 11, 2022, 06:21:38 AM »
The Valkyrie is sensitive to any mods that might impede gravity-powered fuel flow, resulting in fuel starvation.  Too-long fuel line segments, any dips/rises/loops in the fuel line, most fuel filters even those designated for gravity fed fuel systems, fuel solenoids with small orifices, and so on.  I recall fuel disconnects having the problem as well.
« Reply #3 on: May 11, 2022, 07:13:57 AM »
And this is the reason the OE fuel line is a bit of a PITA to unhook and hook.  But any longer is likely trouble you don't want.
« Reply #4 on: May 11, 2022, 07:23:28 AM »
A agree with all the negative comments. I do believe you could eliminate the loops and carefully fit the quick release nipples to the petcock and fuel line. Careful measuring and it may work. I have a Pingel so disconnecting the fuel line is easy
Savage
United States
« Reply #5 on: May 11, 2022, 07:59:26 AM »
I had one of these installed years ago and it resulted in fuel starvation. Mine was installed less than a week before I removed it and installed a fresh OEM fuel line.
Columbia, South Carolina
MotoBob
« Reply #6 on: May 11, 2022, 12:33:05 PM »
I think I’m going to go with the voices of experience here and stay away from this.  Thank you all for the input, and I appreciate the offer Jeff.
Avanti
Stoughton, Wisconsin
« Reply #7 on: May 11, 2022, 04:35:25 PM »
Does anyone know the micron filtration of the OEM in tank filter?
Ron in Buffalo
Buffalo, NY
« Reply #8 on: May 18, 2022, 07:03:37 AM »
Just my 2 cents why do u need fuel disconnect hoses when you have a petcock? Fuel injection quick disconnect are nice.
1997 Valkyrie & 2002 BMW F650GS
