February 12, 2026, 05:00:23 AM
Raising the tank
Topic: Raising the tank (Read 1887 times)
shadowmagic
Raising the tank
May 20, 2022, 05:58:53 PM »
So I'm gonna put some dragon stacks on my bike. Ive been reading up on how to raise the tank and I have a plan, I do need some help in pointing me to a spacer to lift the tank? As i understand it I need to lift it about half an inch on the front end. If anyone can send me a link to a spacer that works for this I would really appreciate it.
Re: Raising the tank
May 20, 2022, 06:44:22 PM »
Ace Hardware has a full selection of spacers. Both chrome and SS. You can’t see it so pile up 3-5 fender washers if you want to save money.
May 20, 2022, 07:33:56 PM »
Quote from: sandy on May 20, 2022, 06:44:22 PM
May 20, 2022, 07:46:02 PM »
You might want to jbweld a single spacer under there - after you determine the thickness you need - to ease installation. I would probably just tack weld it to the bottom of the tank mount tab - with the weld where it could be cut if I need to remove it.
shadowmagic
May 20, 2022, 08:20:39 PM »
Thanks for the tips everyone
Valker
Wahoo!!!!
Texas Panhandle
May 20, 2022, 08:25:24 PM »
I've always used a standard lug nut off a car wheel. The tapered end fits perfectly in the hole and holds it stable.
Reply #6 on:
May 20, 2022, 08:36:06 PM »
You will need to add a little to the rubber bumpers on the frame. I added a section of radiator hose under the stock bumpers.
Reply #7 on:
May 21, 2022, 11:38:15 AM »
Quote from: The emperor has no clothes on May 20, 2022, 08:36:06 PM
Good point! A lot of riders forget about those, adds to the stability of the tank when in place.
jdp
Reply #8 on:
July 08, 2022, 04:55:06 PM »
Why are people raising there tanks ? I guess I’m behind on a lot of things
Reply #9 on:
July 08, 2022, 05:24:01 PM »
Quote from: jdp on July 08, 2022, 04:55:06 PM
To allow for clearance when installing the fake velocity stacks.
RonW
Newport Beach
Reply #10 on:
July 08, 2022, 05:26:39 PM »
you get more mileage raising tank.
Last Edit: July 08, 2022, 10:58:25 PM by RonW
2000 Valkyrie Tourer
