January 30, 2026, 09:22:06 AM *
Author Topic: Scuffed wire repair? Liquid Tape?  (Read 3844 times)
Jeff K
« on: January 19, 2010, 06:00:32 AM »
My Speedo wire got scuffed by the tire. It works fine, but it needs repair.
Has anyone found any GOOD coating that I can repair the cable with.
I've used the standard hardware store "liquid tape" before, and wasn't real impressed.
Surely there must be some high tech way of repairing the jacket on the wire
Spirited-6
Nicholasville, Ky.
« Reply #1 on: January 19, 2010, 06:13:44 AM »
Jeff, I once repaired a cable with "heat srink" Split and slip over cable and add heat. Looks good and blends in.  Wink Good luck.
Spirited-6
Cyclejohn
Reidsville,N.C.
« Reply #2 on: January 19, 2010, 11:13:22 AM »
My local Ace hardware store sells a product called Plasti-Dip. Comes in several different colors and you use it to dip plier handles, rake handles, etc. and I use it to coat and weatherproof wiring also. Probably would work just fine to coat the scuffed part of your speedo cable brushed on with a small hobby brush.
HOZ
If it an't broke, don't fix it
Arlington, Wa.
« Reply #3 on: January 19, 2010, 04:59:07 PM »
They also sell "plasti-dip" in a spray can like spray paint. Would give a more even covering I would think. Good luck.
VRCC #1555
98' Tourer (Black) 157,000mi
99' I/S (Green & Silver) 45,700mi
John U.
Southern Delaware
« Reply #4 on: January 19, 2010, 05:10:53 PM »
If you think there is a chance the same thing could happen again, you might consider vinyl tubing. It comes in black and can be glued on with Permatex Vinyl Sealant Repair Kit. Of course there will be a fat portion of the cable. The Vinyl Sealant can be used by itself if the damaged area is small, but it is a liquid/gell so it may run. Easier done if the cable is disconnected.
 Let us know how it works out.
Madmike
Campbell River BC, Canada
« Reply #5 on: January 20, 2010, 07:00:16 AM »
Heat shrink... if you have trouble getting a small enough size slid over the cable end and it won't shrink down enough you can always do a tape wrap first to make the cable a bit bigger then slide the heat shrink over and shrink it down on the tape.    http://solutions.3m.com/wps/portal/3M/en_US/3MElectrical/Home/ProductsServices/Products/?PC_7_RJH9U5230GE3E02LECIE20OES1_nid=MPJW1L8GGZbe8D163X4VDGgl
« Last Edit: January 20, 2010, 07:03:43 AM by Madmike » Logged
BudMan
"Two's in."
Tecumseh OK
« Reply #6 on: January 20, 2010, 08:14:03 AM »
I use teh Plasti-Dip on teh handles of my ratchets, pull bars and so forth.  It does a great job on them and really stays put! I suspect it would protect the innerds of the spedo cable well.
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
Ratdog
Somewhere out West, Which way did I go?
« Reply #7 on: February 10, 2010, 11:03:52 PM »
A thought?
A piece of tubing (you pick the material) that's just big enough to encase the damaged section.  Split it into two halves, use 'em to splint the affected area and give a good wrapping of electrical tape to hold 'em in place.  Then, use some heat shrink over the splinted repair to weather proof the mend and tidy it up?
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
Friagabi
Tacoma, Wa
« Reply #8 on: February 11, 2010, 01:40:02 AM »
If you decide on Heat shrink be aware that it s available in shrink percent. Some shrinks more than others. Good idea to know the figure before shrinking it and finding out it does not get tight. Also some comes wth water proof glue lining.
Ratdog
« Reply #9 on: February 11, 2010, 09:58:57 AM »
Yup, kinda why my thinking was to encase the damaged area with some more solid tubing first.
