February 12, 2026, 03:01:28 AM *
Author Topic: Yee-Ha an oil question  (Read 1786 times)
« on: May 25, 2022, 12:14:54 PM »
I was given these.
Can I use then in my bike?
https://www.api.org/products-and-services/engine-oil/eolcs-categories-and-classifications/oil-categories#tab-gasoline
« Last Edit: May 25, 2022, 12:17:44 PM by Britman » Logged
3W-lonerider
Shippensburg Pa
« Reply #1 on: May 25, 2022, 12:32:14 PM »
my thoughts are no. that writing in the bottom of that circle that says resourse conserving. tells me there are friction modifiers in it. not good for the clutch.
« Reply #2 on: May 25, 2022, 12:37:43 PM »
What I was thinking.
six2go #152
Ft. Wayne, IN
« Reply #3 on: May 25, 2022, 12:39:16 PM »
I wouldn't, for the above reason plus it's not the correct viscosity recommended by Honda for the 1800.
« Reply #4 on: May 25, 2022, 12:49:06 PM »
Page 46 reveals all.
https://cdn.powersports.honda.com/documentum/MWOM/ml.remawmom.2014_31mjr600_gl1800c_a_valkyrie.pdf
I'll use it in the family vehicles as needed.
h13man
Indiana NW Central Flatlands
« Reply #5 on: May 26, 2022, 06:54:24 AM »
Resource/Energy Conserving, NO. The API circle with no info in the bottom of ring, maybe as there are oils still on the shelf for pre 80's applications believe or not in 10w-40. Usually oil is described to be MC oil. Diesel oil will work but changes made by EPA in 2017 it can be different depending on one's ability to notice changes in shifting/tranny noise. This is what occurred after I ran pre 17' Rotella T6 for 10 yr. and then using post 17' variety. I suggest running MC oil thus $7+ a quart for Honda GN-4 dino will be a minimum price for good MC oil. I changed to Valvoline dino and it broke down @ 3,500 mi. thus I'm using Mobil 1 syn. w/o no issues so far. I can only speak from my experience only.
rug_burn
Brea, CA
« Reply #6 on: May 27, 2022, 12:45:54 PM »
    I been using Mobil 1 15-50 for years, no complaints.   $25 for 5 qts at Walmart.
    In fact-  I usually run mine to about 15k to 20k miles, and the oil still has body, not broken down, and is not saturated with contaminents; but I change it anyway...
   But, that's just me..
...insert hip saying here..
Roadog
« Reply #7 on: May 29, 2022, 04:47:23 PM »
 I run Amsoil 10 W 40 motorcycle specific . Conrains No friction midefiers , safe for wet clutches. 10 years no issues .
rug_burn
Brea, CA
« Reply #8 on: June 01, 2022, 09:53:39 AM »
Wet disc clutches never seem to wear out (rivet issues notwithstanding)... I wouldn't worry about it too much, and I'd use the oil.   Maybe just one quart out of 4 or something like that if you're still concerned.
Grandpot
Fort Mill, South Carolina
« Reply #9 on: June 01, 2022, 12:02:14 PM »
Energy Conserving oils typically contain phosphorus, which is a friction modifier.  It can cause the clutch to slip.  Some users experience this problem, some don't.  To be on the safe side, don't use Energy Conserving oils.
« Reply #10 on: June 01, 2022, 12:59:19 PM »
