November 08, 2025, 06:15:54 PM *
Author Topic: 200 miles yesterday  (Read 1061 times)
« on: June 02, 2022, 08:50:57 AM »
Started out ok and found the newly mounted highway pegs are pretty much spot on for me, yea!  On my return leg it was getting pretty warm even with the vent in the shield open and knees in the breeze. I kept looking at the control panel and wondering, did I leave the seat heaters on or something? Each time I confirmed they were off, so I hit the display button, 90 degrees, now it made more sense. Thankfully the humidity wasn’t that bad on the the last 20 or so miles was in some tree lined twisties and it actually felt quite cool.
Another great day on two wheels versus lamenting the current world conditions. I did come across a gas station that had gas about 40 cents a gallon cheaper than any other I had seen all day and while I did need much I couldn’t pass up a “deal”! The pumps looked busy but I was in no hurry. Good thing too, they had run out of regular and mid grade and shut the pumps down. However there was a supply truck dumping a fresh load and they assured me that the pumps would be back on once he was finished. Ultimately it was a 20-30 minute gas stop and of course customers were milling around and talking as people will do. Maybe just coincidence, just I did not encounter one Democrat amount the customers getting a fill up, at least no one willing to admit it anyway cooldude
« Reply #1 on: June 02, 2022, 09:35:47 AM »
John, I usually won't get gas immediately following a delivery. It tends to stir up debris and although filters are in place, they're not fool proof.
« Reply #2 on: June 02, 2022, 09:54:25 AM »
I actually thought about that but I’m such a hard head I do I any anyway.
« Reply #3 on: June 02, 2022, 12:56:21 PM »
Collective wisdom is to never pump any gas when a tanker is refilling their tanks, or within some time afterwards.  The gunk in the bottom of the tank is mixed with the fast feed tanker fill, and takes a while to settle back down.
If a tanker is in the station, I will never stop.
« Reply #4 on: June 02, 2022, 03:04:55 PM »
Somehow I made it back home, should I pull the gas tank out?
« Reply #5 on: June 02, 2022, 04:15:38 PM »
If she's running fine, no.
I meant no offense John.
« Reply #6 on: June 02, 2022, 05:50:29 PM »
None taken, just my dry sense of humor rearing it’s ugly head Wink
« Reply #7 on: June 03, 2022, 08:58:09 AM »
ugly head Wink
Don't be so hard on yourself John.   While admittedly I'm not inspired, I wouldn't suggest totally ugly....  Wink
« Reply #8 on: June 03, 2022, 01:12:37 PM »
That’s not what you told me when I was at your house during the Spring  Fling!
Pappy!
Central Florida - Eustis
« Reply #9 on: June 03, 2022, 08:00:41 PM »
Down here it is the accumulated humidity (water) in the in-ground tanks that is the reason I will not fill while a tanker is dumping.
Glad you didn't experience that!  cooldude
