February 12, 2026, 03:01:26 AM *
Author Topic: Motor full of gas  (Read 2352 times)
jdp
« on: June 03, 2022, 03:00:41 PM »
My petcock is bad not OEM doesn’t have shut off and my motor filled up with gas no hydro lock yet but what’s the best way to flush all the gas out of my motor ?
Gondul
VRCC #408
Central Florida
« Reply #1 on: June 03, 2022, 03:05:50 PM »
Pull all the spark plugs, put it in gear and start pushing... just watch for the spray of gas.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
da prez
Wilmot Wi
« Reply #2 on: June 03, 2022, 03:47:23 PM »
Drain. Cheap oil filter. Check for hydro lock. If ok , fresh oil. Run for 10 or 15 minutes . Shut off and drain and refill with your regular oil
 F I X carbuerator issue. Or sell it to me.
                da prez
h13man
Indiana NW Central Flatlands
« Reply #3 on: June 05, 2022, 07:23:33 AM »
Pull the plugs, flush the cylinders, and change the oil. Add a Pingle valve and shut off after riding.
« Reply #4 on: June 05, 2022, 07:33:17 AM »
And rebuild carburetors
h13man
« Reply #5 on: June 06, 2022, 06:52:23 AM »
That too! Not much mention about conditions before this happening but float assembly rework for sure and if I read it right no shut off?  Huh?
« Last Edit: June 06, 2022, 06:54:40 AM by h13man » Logged
DeathWishBikerDude
« Reply #6 on: June 25, 2022, 08:50:50 PM »
First thing I do when I buy a call is add a mingle peacock.
I've got a few extras just in case I buy another call.
Turn it off every time I park my bike.
jdp
« Reply #7 on: July 06, 2022, 04:33:24 PM »
Carbs were fixed drained the motor full of gas but lucked out ran oil threw 3 times then add my regular oil but I should have drained the exhaust pipes they were full of gas and oil but it’s all good now back on the road looking for some Harley guys that want to ride ha
