February 12, 2026, 03:01:23 AM *
Author Topic: TPMS  (Read 1607 times)
shadowmagic
« on: June 06, 2022, 03:14:34 PM »
So I installed a tiregard TPMS and it seems to be stuck and I'm unable to reset it. Anybody know how to do some sort of hard reset? all batteries are new and I've left the batteries out for half an hour but the same tire pressures appear even with the sensors off and no batteries installed. Any help greatly appreciated.
TrapperAH1G
Toledo, WA
« Reply #1 on: June 06, 2022, 04:28:55 PM »
Unit will display the last PSI received until you start riding again.  It sometimes takes a mile or two before the sending units update data and display shows current PSI.
If that's not it, you may have to separate the sensors from the display unit beyond their range.  Last, remove batteries from sending units and display over night.  Reinstall sensor batteries and put them back on stems, then install display battery.
Good luck.
SunshineNomad
Ft. Lauderdale
« Reply #2 on: June 06, 2022, 05:58:30 PM »
Mine has done that a couple times. I disconnected and reconnected and they worked.
"Keep thy eye on the tach, thine ears on the engine.
Lest thy whirlybits seek communion with the sun"
shadowmagic
« Reply #3 on: June 06, 2022, 07:09:34 PM »
Thank you for the replies, I will ride it to work and see what happens.
shadowmagic
« Reply #4 on: June 09, 2022, 04:31:17 AM »
Thank you guys for responding. you guys were right. I rode and it settled in and marked the correct the pressure.
