February 12, 2026, 03:00:50 AM *
Author Topic: Led Light Bar  (Read 1539 times)
idaida98
« on: June 13, 2022, 10:23:38 AM »
I have a Blazer Led Strip that I bought at wally world model no c3491rc,it is supposed to be a stop, tail,turn. I would like to mount this on my aftermarket trunk,but I have questions before I start. There are only 3 wires,black to tail,red to stop turn,white to ground.Will this light bar with its circuitry actually differentiate between left and right blinkers and if so will I need a need a different blinker flasher? Thanks
« Reply #1 on: June 13, 2022, 12:17:05 PM »
If it has only 3 wires, then no, it won’t be a blinker. Only tail and brake light.
« Reply #2 on: June 13, 2022, 12:33:59 PM »
Is there a point of contact for the manufacturer in the package/paperwork?
idaida98
« Reply #3 on: June 14, 2022, 04:03:59 AM »
Yes I called their customer service number and of course was put on hold and got cut off twice. I will try again today.In the meantime I will  try to connect it to my  trailer connection and see if I can find out if it works.
Jims99
Ormond Beach Fl.
« Reply #4 on: June 14, 2022, 04:38:24 AM »
Looks as if you will need one for each side. This is a running light, the brake and turn are the same wire. To us on our bikes you’ll see the trailer light adapter that has separate inputs for turn and brake with single wire output. If your bike already has a trailer plug, you can wire into that harness.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Timbo1
Tulsa, Ok.
« Reply #5 on: June 14, 2022, 10:42:28 AM »
Another user has stated having the same problem as you on Amazon reviews.
Quoting
"Running light and stop light only no left/right turn signal like it states but it makes a great third brake light"
https://www.amazon.com/Blazer-C3491RC-Profile-Stop-Light/product-reviews/B004QHGFIY/ref=cm_cr_dp_d_show_all_btm?ie=UTF8&reviewerType=all_reviews
RonW
Newport Beach
« Reply #6 on: June 14, 2022, 02:57:27 PM »
"Looks as if you will need one for each side. ..... the brake and turn are the same wire."
Jim99/00 is correct. The instructions state that the turn and brake wires on the Valk get wired to the same (+) Blazer wire. What this means is it would provide an extra Left turn signal light if positioned on the left rear with the full row of leds blinking. The literature states "For trailers over 80 inches wide," that is, wide enough for a Blazer lightbar on the Right and another lightbar on the Left. Congratulations on your newest souvenir.
The Blazer lightbar won't work like below for the left right turnsignals.
« Last Edit: June 14, 2022, 06:49:05 PM by RonW » Logged
2000 Valkyrie Tourer
