February 12, 2026, 03:01:30 AM *
Author Topic: Front rotor part numbers  (Read 1699 times)
WintrSol
Florissant, MO
« on: June 15, 2022, 12:03:53 PM »
The OEM parts sites show different part numbers for left and right, but EBC shows the same number for both. What am I missing? Is it the drill pattern of the OEM rotors?
RonW
Newport Beach
« Reply #1 on: June 15, 2022, 01:38:04 PM »
they probably designed it so it fits either side of the front wheel. Guessing, though.
2000 Valkyrie Tourer
« Reply #2 on: June 15, 2022, 02:15:55 PM »
It is true that the OEM front rotors are side specific. They should not be interchanged and should be mounted with the direction arrows pointing the correct way for wheel rotation.
WintrSol
Florissant, MO
« Reply #3 on: June 15, 2022, 02:26:42 PM »
When I look at my rotors, I see that the holes go from inside to out, in the direction of rotation. I suppose this is to move anything caught in them nearer the edge. I can't imagine any other reason, as the drilled holes are mostly for looks, anyway. What gets me is that the prices listed are different, for otherwise identical rotors.
RonW
Newport Beach
« Reply #4 on: June 15, 2022, 03:47:59 PM »
good to know that the front rotors are different. I wasn't aware of that until now though I did take both of them off and guess I got them right, didn't mix them up (bliss).
« Reply #5 on: June 15, 2022, 05:03:03 PM »
As a side note, GL1800 rotors are interchangeable. I had them on my previous Valk and liked them. They are lighter and .5mm thinner but it doesn’t cause any problems.
« Reply #6 on: June 15, 2022, 05:40:09 PM »
It’s easy to check. They have little arrows just like tires pointing (hopefully) in the direction of rotation
RonW
Newport Beach
« Reply #7 on: June 15, 2022, 09:32:57 PM »
Yea, go it right.
RonW
Newport Beach
« Reply #8 on: June 16, 2022, 09:58:50 PM »
Yea, go it right.
meant "got" it right, of course.
