February 12, 2026, 03:00:56 AM *
Author Topic: Acetone carb cleaner rocks the house  (Read 2167 times)
DeathWishBikerDude
« on: June 25, 2022, 08:31:04 PM »
I picked up a low mileage (20,000 miles) valk for $3000.
Low speed jets were obviously dirty as low speed operation was rough...once rpm was up bike ran fine.
Every few tanks of fuel I would add a few ounces of acetone to the fuel.
Took the bike out today for the first ride of the season and the rough low speed operation is gone completely.
I didn't drain the carbs before winter.
Parked the bike after the last ride and magic happened.
I was so happy today when the bike just ran perfect.
« Reply #1 on: June 26, 2022, 01:54:24 PM »
Very dangerous for a Valkyrie. The floats are all plastic. Acetone is plastic’s arch enemy. Hopefully it didn’t deform the floats
« Last Edit: June 26, 2022, 02:01:36 PM by Chrisj CMA » Logged
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: June 27, 2022, 07:09:03 AM »
Not to mention the rubber tips on the float valves. Next time try B-12 gas treatment.
2001 black interstate
2003 Jupiter Orange wing
Bagger John - #3785
« Reply #3 on: June 27, 2022, 10:07:48 AM »
+1.
Has smoothed out a number of rough runners for me.
luftkoph
E U.P. Mich
« Reply #4 on: June 27, 2022, 12:04:39 PM »
A few ounces in 5 gallons probably doesn’t hurt anything, here’s from the MSDS on berry mans B12 not all that friendly either, that is if you ran it heavily concentrated.
Xylene is the 40-50%
Section 3 – Composition / Information on Ingredients
Ingredient
Ethylbenzene Petroleum Distillates n-Propanol
Xylene (mixed isomers)
CAS Number
100-41-4 64742-47-8 71-23-8 1330-20-7
Weight
10-15% 30-40% 5-10% 40-50%
Some day never comes
h13man
Indiana NW Central Flatlands
« Reply #5 on: June 29, 2022, 06:11:15 PM »
Berryman user here also. Used as solvent to clean the jets of a GW. I used Seafoam to clean my Valk when I first got it. 2 mi. later the dragon awoke that was 9 yrs. ago and I haven't touch the carbs other than checking the synch. Replaced the manifold o'rings with Viton o'rings. I'm sure old age will rear its head but all is good so far.
