February 12, 2026, 03:00:40 AM *
Author Topic: Valk headlight  (Read 1711 times)
RonW
Newport Beach
« on: June 29, 2022, 11:39:29 PM »
What's the chrome cone in the Valk's headlight for? I use the same Valk bulb in my other bike because it's cheaper, but the Valk headlight is way brighter with the same bulb.
The headlight in my other bike doesn't have the chrome cone. Haven't seen it in any other bike either.
2000 Valkyrie Tourer
Jims99
Ormond Beach Fl.
« Reply #1 on: June 30, 2022, 04:13:21 AM »
I believe it’s to help divert the light to the reflectors and keep any strays from shooting out the front.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Bagger John - #3785
« Reply #2 on: June 30, 2022, 07:07:40 AM »
Look at the feed horn of your typical microwave/radar antenna and where it's positioned in the parabolic curve.
The layout here is similar. For those who are bored and wishing to play with a little math, I can point you to some formulae for calculating the position of the illuminating source, primary and secondary reflectors for frequency X and horizontal/vertical beam widths of Y and Z degrees, respectively. This assumes a beam of 0 degrees H/V skew - divergence calculations are a little more involved.
« Reply #3 on: July 05, 2022, 05:40:51 PM »
https://www.candlepowerforums.com/threads/purpose-of-cups-inside-headlight-reflector.270504/
RonW
Newport Beach
« Reply #4 on: July 05, 2022, 08:35:31 PM »
Good link! and thanks for enlightening me. If you don't mind, summarizing, the cone is known as a bulb shield or an anti-glare shield for oncoming traffic. A poster in the link stated that the inside of the shield (cone) isn't chromed, so the purpose of the shield isn't so much to redirect the bulb's light back to the parabolic reflector. Also, although H4 bulbs have a blackout tit, it's not enough to shield all the glare.
« Last Edit: July 06, 2022, 02:01:48 AM by RonW » Logged
« Reply #5 on: July 06, 2022, 06:20:26 AM »
I took mine out and shortened the end about 3/16". I posted about this, but I didn't save it and haven't been able to find it. it changed the light cutoff and now puts more light on the road.
