February 12, 2026, 03:01:30 AM
Looking for a desmog kit
Topic: Looking for a desmog kit (Read 1831 times)
Unlaoised
Ireland
July 02, 2022, 11:34:02 AM »
Anyone know where to order a desmog kit - can't find one online anywhere?
jdp
Re: Looking for a desmog kit
July 02, 2022, 08:26:13 PM »
Check out
Jared Hinkle
864-764-9550 or
F6valkyrieman@gmail.com
He has a website and is like a god when it comes to these bikes, I just got a desmog kit and put it on my bike, give him a call, great guy to deal with
da prez
Wilmot Wi
July 03, 2022, 06:37:53 AM »
14mm freeze plugs. (not 9/16 th) I buy a full box from Auto Zone for $6.00. Pinch off the air tubes and JB weld from the inside. The gaskets will usually reseal. I have some high temp sealer that I use if needed. Remove the pair valves and reinstall the bolts with sealer. I heard of one rare case where one hole was drilled thru into the block causing a vacuum leak. Plug the air cleaner tube ( I cut off and ABS glue the hole shut). Make or buy the plugs for the intake runners. Use gas proof vacuum line. Hook the vacuum fuel line to the right rear intake runner. It is easier. After doing about twenty or so of them , it is real easy.
Not difficult , take your time and ask if a problem occurs.
da prez
mello dude
Dayton Ohio
July 03, 2022, 11:01:34 AM »
So the real question is.......did Redeye stop making them?
da prez
Wilmot Wi
July 03, 2022, 11:18:16 AM »
Redeye still shows the kit. I talked to a couple of guys that could not get them.
da prez
Tazman11
Idaho
July 03, 2022, 12:22:10 PM »
He showed out of stock so I sent him ab email. Received the a week later. EZY PZY.
Craig9409
Lakewood, WA
Reply #6 on:
July 03, 2022, 09:16:35 PM »
Quote from: Tazman11 on July 03, 2022, 12:22:10 PM
I'm not following your reply? You received the kit a week later? Where did you email him?
Tazman11
Idaho
Reply #7 on:
July 04, 2022, 05:25:45 AM »
PM sent
Unlaoised
Ireland
Reply #8 on:
July 08, 2022, 05:55:02 AM »
Hi Craig, can you PM me too?
Thanks.
