February 12, 2026, 03:00:49 AM *
Author Topic: anyone have a source for the 2 curved bolts  (Read 1967 times)
« on: July 22, 2022, 05:07:35 PM »
that go in for the red valk lift adapter
Both of mine went to that black hole that takes the 10mm sockets
Savage
United States
« Reply #1 on: July 22, 2022, 05:40:03 PM »
I only clicked on this thread because the title read “Two Curved Bolts”,
and I just had to know what the hell you were talking about.
But now that I know, I’m interested when you find a source - one of mine vanished as well.
Columbia, South Carolina
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: July 22, 2022, 05:54:35 PM »
They're just regular bolts that have been heated and bent. Any local welder or guy with a torch and vise should be able to make some. I lost mine also and ordered them from the guy (Maybe MarkT) who made my adapter who sold me two more. Then, of course, I found my two missing ones.
h13man
Indiana NW Central Flatlands
« Reply #3 on: July 23, 2022, 07:08:51 AM »
Mark T's adaptor takes these style adaptor bolts.
http://www.valkyrieforum.com/bbs/index.php/topic,105040.0.html
« Reply #4 on: July 24, 2022, 05:34:23 AM »
Spoke to MarkT  all will be fine soon
« Reply #5 on: July 25, 2022, 06:10:20 AM »
They’re basically foundation bolts right? Pick them up at any building supply.
« Reply #6 on: July 26, 2022, 01:16:48 PM »
No they aren't.  I make them from 1/2" X 13 thread bolts.  Cut off the heads, heat with acetylene torch, bend 90°, cut the thread end to the right length for clearance and chamfer.  I found no similar bolts, looked for them & found I had to create them.  At first I welded them but found the hard way hot-forged are stronger.  Now if such a bolt exists with the right dimensions and strength I would be all over buying them instead.
I'm finding similar shaped bolts now.  Might be I can find and order them instead.  Hope so.  I'm just now making another batch; no doubt it would be cheaper to buy them pre-made, rather than buying conventional bolts and spending the labor and gas to modify them.
« Last Edit: July 26, 2022, 01:19:48 PM by MarkT » Logged
psckam
Elmira, New York
« Reply #7 on: July 26, 2022, 02:41:21 PM »
I did the same as Valker, bolts heated and bent. I used a Mapp torch and my vise.
