February 11, 2026, 11:37:45 PM *
Author Topic: Tripometer fault  (Read 1806 times)
Knapdog
South Wales, UK
« on: August 01, 2022, 03:04:25 AM »
I'm careful to reset the tripometer back to zero every time I fill up with petrol but after a while the "hundreds" dial starts moving.
It's currently showing 447 miles yet I've only done 47. This is the first time it's jumped that much. It usually just jumps up to "1".
On other occasions it acts perfectly as normal.
I don't just reset it the once, to zero. Since I've noticed the error I rewind it back to zero a few times to make sure it's reset.
Anyone else had this problem and is there a fix?
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: August 01, 2022, 05:43:23 AM »
My Hondas have been doing that since the 1960s. Cure is easy, just reset it to 999.9 every time. It only makes a .1 mile difference, but it cures the issue.
h13man
Indiana NW Central Flatlands
« Reply #2 on: August 01, 2022, 07:15:20 AM »
Mine done it twice in 9 yrs. I usually can "feel" the sweet spot by going slow to the final numeral.
WintrSol
Florissant, MO
« Reply #3 on: August 01, 2022, 07:17:21 AM »
:cooldude:I'll have to remember this if mine misbehaves.
Bagger John - #3785
« Reply #4 on: August 01, 2022, 08:09:28 AM »
A couple of the mechanical ones I've had on Valks over the years would hang on 9.9.
Knapdog
South Wales, UK
« Reply #5 on: August 01, 2022, 12:59:29 PM »
Good grief. Sounds as if this could be the answer.
Many thanks.
I'll get back to you.
'96 Honda C90
'83 Honda C90C
