February 11, 2026, 11:37:22 PM *
Author Topic: Avon Tires  (Read 2839 times)
DragonRdr
Gardner, MA
« on: August 01, 2022, 09:22:15 AM »
It's that time again. I need to consider buying new tires for the Valk. So I'm going to poll all the experts out there. I bought Dunlop's for the GoldWing last year and I really like them so that's one option. Or, should I buy Avon's again? Is there a better tire out there? Also, what tire pressures are you all running on your tires? I ride one up most days and I put 34 in the front and 36 in the rear. Thanks in advance.  Smiley
2000 Valkyrie Interstate
1994 Goldwing Interstate
« Reply #1 on: August 01, 2022, 09:57:42 AM »
I’ve ridden Dunlop’s, Metzler and Avons through 2 gens. Not ridden the chromes yet but Avons are the best tyre for a Valkyrie. On my ‘05 Wing I ran Bridgestones which were both cheap and handled the best.
F6Dave
« Reply #2 on: August 01, 2022, 09:59:39 AM »
I switched to Bridgestone and am happy with the change. Avon raised prices so high that I decided to try something else, and I'd also had QC problems with Avon more than once. I checked my usual sources last week and an Avon rear was $265, while the Bridgestone was $195.
Nightflight99
DFW, Texas
« Reply #3 on: August 01, 2022, 10:06:29 AM »
I just ordered a set of the Avons. $517.19 shipped from RockyMountain, but Avon is offering a $60 rebate for the set. Still a lot of cash, but as long as these will last for a while, I won't b!tch too much.
2000 Honda Valkyrie Interstate
2001 Honda Valkyrie Standard
2010 Triumph Street Triple
2017 Triumph Rocket III Roadster
2016 KTM 690 Enduro R
2021 Triumph Rocket 3 GT
DragonRdr
Gardner, MA
« Reply #4 on: August 01, 2022, 10:29:40 AM »
Thanks everyone, I am leaning towards the new Avon Chrome tires. Rocky Mountain looks like a good source. I also don't mind paying a little more if the tires last for a while.
Thanks again  cooldude
« Reply #5 on: August 01, 2022, 11:15:34 AM »
I have Avon Chrome on now. I get well over 20,000 Miles running 40psi in the front and 42psi in the rear
DragonRdr
Gardner, MA
« Reply #6 on: August 01, 2022, 11:26:32 AM »
« Reply #7 on: August 01, 2022, 01:12:59 PM »
I have Avon Chrome. I get five or six thousand on the rears and eight or ten
on the fronts... about the same as with other tires...
« Reply #8 on: August 01, 2022, 01:23:54 PM »
If I was lucky (since 2005 on Valks), I could get 8K out of motorcycle tires front and rear.  And I run them hard (a pound or two under the max psi printed on the sidewalls).  Run car tires for many years now and get over 30K, but the fronts, I still have to be lucky to get 8K.  And I tried a double darkside front and got 7K, so I'm done with that.
Jeff reporting 20K in the Panhandle makes me think the roads there must be made of marshmallows.   Grin
Though we know it's flat (and the highest elevation in the whole sate is a bit over 300 ft).
Gondul
VRCC #408
Central Florida
« Reply #9 on: August 01, 2022, 05:45:09 PM »
I've run Dunlop, Bridgestone, Metzler and a car tire... every time I swap back to Avons and those are what I'm currently running.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
pais
One more turn should do it!
Kent, Ohio
« Reply #10 on: August 02, 2022, 06:07:34 AM »
When I bought my Valk 9 years ago, it needed tires.
I bought the Avons  and installed them front and rear. Like many on here I am amazed at the mileage Chris got out of his Avons. I had cords showing on the front tire and the rear wasn't far behind. I got about 12k miles out of the set. Actually seems like low miles for the front and high miles for the rear. We do have quite a few chip and seal roads here in NE Ohio. I ran 42psi front and rear.
I recently just replaced both front and rear tires with Dunlop 4's. I switched just to try the Dunlops. Dunlops are what I ran on my other bikes over the years.  Only thing different other than the tires is I am now running BB's in both rather than balance weights. Bike feels good with the new rubber but don't they always.
F6Dave
« Reply #11 on: August 02, 2022, 07:46:17 AM »
I've been amazed at the range of tire mileage. Some of us get only 8K miles from a rear, while others get 20K. I usually get a bit over 10K from a rear and several thousand more from the front.
Interestingly I got better mileage out of the old Avon Venoms, that were replaced by the Cobras. I could easily get 12K to 13K from a rear, and on the front I got well over 20K. Those were good tires unless you got a defective one, which was not uncommon. Many of the front tires would wobble in turns. Over the years I've had more tire problems with Avons than any other brand.
