February 11, 2026, 11:37:20 PM *
Author Topic: relay, wire where does it go?  (Read 2141 times)
sutterhome
« on: August 01, 2022, 05:00:38 PM »
Can someone tell me where this position 86 black wire attaches to. It's about a foot long and I cant see where it broke off of.
or might  this be  just an addon relay for fog lights that a can remove till non starting issue are resolved?
« Last Edit: August 01, 2022, 05:43:31 PM by sutterhome » Logged
Gondul
VRCC #408
Central Florida
« Reply #1 on: August 01, 2022, 05:42:20 PM »
 :question:That's not OEM as far as I'm aware, could go anywhere depending on how it was wired in...where do the remaining wires terminate?
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
sutterhome
« Reply #2 on: August 01, 2022, 05:48:34 PM »
switches the fog lights on once stated I think? Not my wiring but have a no electrical power no starter, lights etc. Need to check the start switch tomorrow
Started up fine.... died and that where we are now
RonW
Newport Beach
« Reply #3 on: August 02, 2022, 02:55:06 AM »
"Can someone tell me where this position 86 black wire attaches to. It's about a foot long and I cant see where it broke off of."
My guess is the relay's 86 trigger wire is tapped into the headlight wire. This causes the fog lights to mimic the headlight. ON when ON. OFF when the key is turned OFF, and momentarily OFF when the start button is pressed in. Not withstanding a on/off switch on the fog lightbar itself.
The headlight wire is blue with white stripe. It's located in the wire loom that runs from the Right handlebar clamshell to the headlight bucket then to the Left handlebar clamshell. In the bucket itself, the headlight wire (Bu/W) plugs into bullet connectors on its way over to the Left handlebar's Hi/Low switch.
86 could just as well be tapped into the low-beam wire such that the fog lights turns ON only on low beam for legal reasons. The low-beam wire is a white wire in the H4 plug in the headlight bucket.
"..... or might  this be  just an addon relay for fog lights that a can remove till non starting issue are resolved?"
No harm. Just bear in mind the hidden broken-off end of the 86 wire remains hot whenever the key is ON. Also, Wire 30 is hot. You might want to double check that Wire 30 is not tapped off the headlight wire to power the fog lights. Bad juju.
« Last Edit: August 02, 2022, 09:42:26 AM by RonW » Logged
2000 Valkyrie Tourer
RonW
Newport Beach
« Reply #4 on: August 03, 2022, 12:49:49 AM »
Rattlebars schematic with 86 trigger terminal wired to the headlight wire.
SCain
Rio Rancho, NM
« Reply #5 on: August 03, 2022, 06:09:59 AM »
Follow the wire attached to terminal 87 and see where it goes.
Steve
RonW
Newport Beach
« Reply #6 on: August 03, 2022, 11:52:50 AM »
If you meant 86 wire (Orange arrow). By the clean cut of the insulation, the wire might have been crimped to, then yanked out of a blade or bullet connector. (sutterhome's photo.)
« Last Edit: August 03, 2022, 11:55:34 AM by RonW » Logged
F6BANGER
Albuquerque NM
« Reply #7 on: August 04, 2022, 12:01:55 PM »
Steve Cain is correct. 86 is the signal input. If 87 goes to powerful horns, then 86 would be the trigger  from the horn button. If 87 goes to fog lights, then 86 would be the trigger wire from the lights.
RonW
Newport Beach
« Reply #8 on: August 04, 2022, 01:21:09 PM »
sutterhome inquires where, or to what, the 86 wire was connected to. Quote below.
"someone tell me where this 86 black wire attaches to. It's about a foot long and I cant see where it broke off "
« Last Edit: August 04, 2022, 01:24:17 PM by RonW » Logged
indybobm
Franklin, Indiana VRCC # 5258
« Reply #9 on: August 05, 2022, 06:25:24 AM »
No matter what this wire was attached to I doubt if it is causing the no-start condition. My first thing to check is always the red cap on the starter relay. Pull it off and check for corrosion/melting. This happens way too often.
So many roads, so little time
VRCC # 5258
sutterhome
« Reply #10 on: August 05, 2022, 09:50:51 AM »
Thanks, that connector has seen better days.I am going to jump it out when its not a million degrees in the driveway and see it thats the issue, then look at the start switch.
Does a bad red connector kill everything?
Although with a bad start switch shouldn't  I have  basic lights neutral lights, dash lights etc?
Jumped out the red connector.Still have no electrical lights, starter, neutral lights.. zero. Can reed 12.7 at starter relay. Tried jump the with the relay 2 top screws.... nothing.
« Last Edit: August 05, 2022, 11:13:16 AM by sutterhome » Logged
sutterhome
« Reply #11 on: August 05, 2022, 02:33:42 PM »
found the gremlin...... engine ground. GEEZ Cant get a good angle at the top bolt..Thinking that repositioning it to anywhere else is a good thing.
john
tyler texas
« Reply #12 on: August 11, 2022, 08:03:29 PM »
access up and over the swingarm with a long 1/4 drive extension and socket ...      pita but doable
vrcc # 19002
