February 12, 2026, 01:14:05 AM *
Author Topic: parasitic draw on interstate  (Read 2558 times)
« on: August 04, 2022, 04:00:37 PM »
I got a new battery this spring and had a nice 3000 mile ride last month
had not ridden the bike since mid June
This evening I went to start the bike and so dead no lights on dash even lite up
it is parked in my garage out of the sun
I have suspected a parasitic draw for a while
how do I go about trying to isolate it?
It is now on my bmw 2 amp charger
« Reply #1 on: August 04, 2022, 04:14:33 PM »
Have you installed a bluetooth receiver? If not look for anything installed on a hot wire before the ignition that could be pulling power continually.
My bluetooth is unswitched and always on.  It's low draw but it can suck the juice down.  No problem since at home I use a trickle charger/desulphator. I left the fuse accessible so I can pull it when I'm traveling or during the winter off season.
This summer's flying by.  Sorry for the using the "w" word.
« Reply #2 on: August 04, 2022, 04:40:32 PM »
New battery or not, why do you suspect a parasitic draw if it has not run since mid June (in hot summer)?
A stock interstate has some memory items in the dash (speedo & radio), but draw is really minimal.  Do you have anything added?
If the battery went clear to the bottom, it may now be unreliable (or not).
Avanti
Stoughton, Wisconsin
« Reply #3 on: August 04, 2022, 05:29:35 PM »
A Signal Boss has some draw if you have one installed.
« Reply #4 on: August 04, 2022, 06:02:58 PM »
Evan; If you have a Volt Ohm meter, disconnect the neg terminal. Hook up the meter between the neg battery and the neg wire. With key “on” check the milliohms. Pull 1 fuse at a time till the reading drops. That will tell you which circuit may have an excessive draw.
RonW
Newport Beach
« Reply #5 on: August 04, 2022, 06:41:40 PM »
Key should be OFF.
If memory serves, should not exceed 50 milliamps.
2000 Valkyrie Tourer
« Reply #6 on: August 04, 2022, 09:01:05 PM »
Key should be OFF.
I stand corrected also it should have been milliamperes , not ohms.
Challenger
Posts: leet
« Reply #7 on: August 05, 2022, 07:08:22 AM »
I found the draw on my I/S by accident.  I replaced the brake light with an LED bulb and noticed one night while it was sitting  in the garage that the tail light was barley glowing. Found the Audiovox Cruise Control was bleeding through the brake wire. Probably not your problem, but shows you how weird electrical gremlins can be.
Bagger John - #3785
« Reply #8 on: August 05, 2022, 07:27:04 AM »
The I/S stereo radio and the Hondaline CB radio will both put enough of a draw on the battery that it'll noticeably decrease its available power in one to two weeks. As in, may not start the bike.
FWIW, the previous GLs which were equipped with battery-backed memory will do same.
Simple fix is to keep the bike connected to a Battery Tender any time it won't be ridden for more than a day or two.
« Last Edit: August 05, 2022, 03:37:36 PM by Bagger John - #3785 » Logged
Earl43P
Farmington, PA
« Reply #9 on: August 05, 2022, 09:54:08 AM »
The I/S stereo radio and the Hondaline CB radio will both put enough of a draw on the battery that it'll noticeably decrease its available power in one to two weeks. As it, may not start the bike.
Mine has an AGM and stays charged enough to reliably start after 4 weeks, maybe more. I would never expect it to be completely dead like his was after 7 weeks.
Simple fix is to keep the bike connected to a Battery Tender any time it won't be ridden for more than a day or two.   I do use a tender, but mostly in the winter months when I ride less.
Evan, you don't need a multi-meter if you aren't competent with one. KISS method: Take off the Battery negative terminal. With key off, touch it back to the battery- post in dim light, not sunlight. Note the sound and spark intensity when you touch it back to the battery. Pull suspect circuit fuses one at a time until the spark intensity is negligible and almost silent, that last fuse is the circuit pulling the draw.
If it never lessens, suspect the alternator. Disconnecting its B+ lead will tell that tale.
Highly unlikely to be the alternator, but possible. Also possible is any accessory you have connected directly to B+, so do those by pulling their inline fuse.
Good luck,
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
« Reply #10 on: August 05, 2022, 07:40:07 PM »
Thanks all
I will charge the battery when I wake up so there is enough juice to test
edit
all day on the tender then the smart charger   The battery is totally dead
I am charging a just about dead battery overnight so I can do the multimeter tests tomorrow
I did buy a usb charger tail before my last trip and wonder if that is the culptit if not the fog circuit
« Last Edit: August 08, 2022, 07:29:04 PM by Oss » Logged
3W-lonerider
Shippensburg Pa
« Reply #11 on: August 07, 2022, 12:52:38 PM »
depending on the type of usb charger. yes. they are active and bleed off even if nothing is plugged into them.
Jims99
Ormond Beach Fl.
« Reply #12 on: August 08, 2022, 04:47:33 AM »
Just left my usb charger on (switched) last Sunday, went to start bike Friday, dead battery. So I agree, could very well be the usb.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #13 on: August 08, 2022, 06:42:40 PM »
Battery is still dead as a doornail
I emailed the folks that sold me the YUASA battery and for 9.95 will send me a new one after I take a pic showing its dead, dead dead   Kinda like the wicked witch of the west after she got melted
In the meantime I have learned a lesson   Just not sure what it is yet besides
a  Only plug in a usb charger into the charging tail while riding
b  use the DAMN SMART CHARGER THAT DESULFATES ETC (ok jess?) if more than a week off the bike
c   pull fuses one at a time to see what else is drawing once I get that new battery in the bike
I have one old battery that I have charged up to   wow   3.5 volts,  so during this weekend I will see it I can track anything down
Thanks for the input  appreciate it !
I have a Battery Minder Model 128CEC1
« Last Edit: August 08, 2022, 07:28:44 PM by Oss » Logged
« Reply #14 on: August 08, 2022, 06:59:16 PM »
b  use the trickle charger if more than a week off the bike
Not a trickle charger Evan, a low voltage smart charger that cycles on and off.
Get one with an in line fuse, and run it from a GFCI protected plug, or use a power strip with another fuse in it.
I've used these for many years with no trouble or fire or cooked battery, and my batteries last a long time.  They come with a pigtail to run to the battery terminals and I ziptie the SAE plug to the frame down by a passenger peg.  Ride in, and plug in, every time.  A steady green led means the battery is topped up.  It comes with a 12 foot cord, if it's farther far from your electrical plug, you can get extensions.
https://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1_sspa?crid=94ZBZTYWGMK6&keywords=battery+tender+jr&qid=1660009863&sprefix=battery+tneder+jr%2Caps%2C149&sr=8-1-spons&psc=1&smid=AC0UA62Z9ZBMG&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExN01FT1FBTVBJTEdIJmVuY3J5cHRlZElkPUEwMjI4MTQ0MzBRMTVWSkRCVkI2WCZlbmNyeXB0ZWRBZElkPUEwNjg2MTEzMUVPMjA3OEpMSE5KRiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
« Last Edit: August 08, 2022, 07:02:20 PM by Jess from VA » Logged
« Reply #15 on: August 10, 2022, 09:59:51 AM »
Warranty  honored and new battery on its way
9.95 shipping  ok in my book
Parts giant  cooldude
Battery charged friend coming over tomorrow morning so we can try to trace the draw
« Last Edit: August 26, 2022, 02:42:32 PM by Oss » Logged
« Reply #16 on: August 27, 2022, 02:00:23 PM »
surprise
The red positive cable that goes from starter to battery was so fatigued that it actually broke on the battery side when I was trying to get the battery in the compartment it slides into  So perhaps the battery was never getting the benefit of a full charge?
Ordered a new one off ebay and it will arrive by next weekend
We did test and there was no draw coming from the usb connection  That was a nice surprise.
Some of the connections on the aux fuse panel we will redo next weekend when we get that large gauge wire back on and will clean up all the connections under the seat.
fortunately I have a spare bike to ride
I did ride Steve's Harley after lunch.  I believe it has around 150 hp, a very heavy duty clutch as he had blown thru one before, switched from belt to huge chain drive, modified the spoke wheels so he can run tubeless tires.  I forget the process.    it almost looks like chopped.
minimalist no bags or trunk just a shorty windscreen .  Custom paint job he did himself.
The thing rides like a monster less than 500 lbs, fuel injected pulled like a rocket 3   I had fun riding it for a while on some local roads and opening it up on 9a
Next week I will take a picture of it
RonW
Newport Beach
« Reply #17 on: August 27, 2022, 02:59:07 PM »
"The red positive cable that goes from starter to battery was so fatigued that it actually broke on the battery side"
I guess it's worth inspecting that 20 year old crimp. Does copper get brittle from conducting electricity heating it up?
« Reply #18 on: August 27, 2022, 05:05:22 PM »
surprise
The red positive cable that goes from starter to battery was so fatigued that it actually broke on the battery side ...
I had the same issue with my Istate.  Symptoms made me believe I had a failing alternator but it was only the cable that was failing.
