February 11, 2026, 11:37:34 PM *
Author Topic: A little electrical help  (Read 2247 times)
valkmc
Idaho??
Ocala/Daytona Fl
« on: August 12, 2022, 03:30:44 PM »
Trying to get the Valk back together after I was rear ended. I assume that the two greens coming out of the likes go right and left. Since there are six wires out of the lights and only 5 out of the harness that the green from  license light
doubles up on one of the greens out of the harness. That leaves a blue, brown and orange. Blue to the blue from the license plate  light. CanI just hook brown from the harness to brown from the lights and orange to orange?
Does it matter which green two greens I double up.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Bagger John - #3785
« Reply #1 on: August 12, 2022, 04:07:10 PM »
Have a copy of the wiring diagram in the Service Manual? It should show the relationship for all those.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #2 on: August 12, 2022, 04:35:12 PM »
Thanks I-have a digital Clymer but not much help !
bassman
« Reply #3 on: August 12, 2022, 05:09:52 PM »
Anything here help?
https://mega.nz/file/EgMilRQR#qwBVH4H12_mxGSYPaWEt_BtYjust3pa8o8NkEWnDFlE
Ramie
2001 I/S St. Michael MN
« Reply #4 on: August 12, 2022, 05:56:06 PM »
Green is ground so it doesn't matter.
RonW
Newport Beach
« Reply #5 on: August 12, 2022, 06:24:33 PM »
Double up the turn signal grounds.
« Last Edit: August 12, 2022, 06:26:47 PM by RonW » Logged
2000 Valkyrie Tourer
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #6 on: August 13, 2022, 03:58:12 AM »
Thanks everyone. I got them working and am currently putting the the bottom half of the rear fender back on.
« Reply #7 on: August 13, 2022, 09:37:50 AM »
That's definitely one everyone should bookmark.
RonW
Newport Beach
« Reply #8 on: August 13, 2022, 11:55:54 AM »
Btw, Ramie was also right, ground is ground.
"I got them working and am currently putting the the bottom half of the rear fender back on."
if you get trouble aligning the bolt for the nut cage, try wiggling the rear fender at Spot A.
Re: installing the turn signal thingie back on the rear fender. I tighten Screw 26 (orange arrow) before tightening down the fender bolts in that order. Otherwise, the fender bolts compress the rubber gasket in such a way that Hatch 16 is kept from fully seating. This throws off the alignment of Screw 26 to it's threaded inserts (A). Doesn't take much to tear the threaded inserts out of it's 20 year old plastic bosses. Recap, attach Hatch 16 to Lower Half 15, then tighten them as a unit to the rear fender with the fender bolts.
Having said all that, you do usually follow this order anyway. But it's when for example you remove the hatch to work on the turnsignals, it's worth your while to loosen the fender bolts before removing the hatch so it can be reinstalled in the proper order.
This is the edge that'll get hung up on the rubber gasket preventing the hatch from seating properly. The rubber gasket doesn't have enough give.
Perhaps, this graphic does a better job at explaining the theory. The fender bolts pull only the Bottom Half 15 tight to the fender. Thusly it's better to line up the hatch to the bottom half and screw them together before tightening down the fender bolts. Again, in that order. Might be just my bike, but I don't think so.
« Reply #9 on: August 13, 2022, 01:44:01 PM »
RonW, I must commend you on your detail of such help. Your ability to link, highlight, add to schematics and pics, etc. is top notch !  cooldude
RonW
Newport Beach
« Reply #10 on: August 13, 2022, 02:30:30 PM »
Thanks, emperor. Well, I gave up trying to explain things in 50 paragraphs or more a while back already. Figured pics are the way to go mainly because detail is so much easier to articulate. And people are less likely to get things mixed up too vrs. speedreading text.
« Last Edit: August 13, 2022, 03:23:08 PM by RonW » Logged
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #11 on: August 14, 2022, 03:53:18 AM »
I agree. I had a heck of a time getting one of the rear fender bolts to line up. Pushing on the fender in the spot RonW shows in his post made the bolt pop right in!
RP#62
Gilbert, AZ
« Reply #12 on: August 20, 2022, 09:01:52 PM »
I never knew anyone had colorized these.  I drew them up about 20 years ago and had Chet (Rattlebars) post them on his site.  Glad to see they're still of use.
-RP
Mooskee
Southport NC
« Reply #13 on: August 21, 2022, 09:08:12 AM »
-RP
Thanks for drawing those up. They are by far the best set of schematics for our bikes. I always thought they were drawn by Chet. Am I correct in thinking they are public domain?
RP#62
Gilbert, AZ
« Reply #14 on: August 21, 2022, 09:34:46 AM »
-RP
Yes indeed, they're for the Valkyrie community.  One of my jobs back in the day was drawing aircraft wiring diagrams for large commercial fleets, based on the engineering documents.  Mine lean towards the Boeing style as I did the Boeing fleets more than anything else.
-RP
baldo
Youbetcha
Cape Cod, MA
« Reply #15 on: August 21, 2022, 01:23:50 PM »
-RP
Mmmmmm....Boeing.
Mooskee
Southport NC
« Reply #16 on: August 21, 2022, 04:47:20 PM »
I have used them extensively and never found an error. Excellent work.
RonW
Newport Beach
« Reply #17 on: August 21, 2022, 05:59:25 PM »
-RP
Your 20 year old schematic has increased exponentially in value. Not sure if the General Notes was yours or Rattlebars, or Rattlebars added to it, but notes like Tip 7 in the General Notes specifies the location of a given component, awesome, (pic. below) vrs. the bare bones factory schematic.
I don't know what kind software you had access to 20 years ago, but even by today's software, it's an incredible feat drafting out the schematics. Then proofreading jumping back and forth to the factory schematics which would wear out most people's eyeballs. (by Mooskee's account Post 16 above, there's no errors.)
If anybody hasn't downloaded the link yet I recommend they do so because try with all your might finding it later.
Anyways, it was rattlebars that colorized the wiring on your schematic?
« Last Edit: August 21, 2022, 06:46:31 PM by RonW » Logged
RP#62
Gilbert, AZ
« Reply #18 on: August 22, 2022, 09:25:56 AM »
Thanks guys.  I put the notes on so you'd know were I was going with the drawings.  I originally did these in PowerPoint (then converted them to pdf's).  Probably not the best for this, but its what I had at the time.  I don't know who colorized them, in fact, I didn't know they were colorized until this post.  The factory diagram drove me crazy. It shows all the circuits, but when you're troubleshooting, you don't want to have to pick out one system from the whole bloody thing.
-RP
RonW
Newport Beach
« Reply #19 on: August 22, 2022, 11:24:29 AM »
  • you don't want to have to pick out one system from the whole bloody thing.
-RP
7 isolated circuits by my count!! Again, the component's location is invaluable (orange rectangle).
