March 15, 2026, 09:04:46 AM *
Author Topic: Dave's Adventure In Electrical Land  (Read 3586 times)
Valkpilot
What does the data say?
Corinth, Texas
« on: January 22, 2010, 07:31:26 PM »
Ride the bike to work this morning.  No problems.
Leave work and ride the bike to SunNfunSue's shop for a hair cut.  No problems.
Leave SunNfunSues's and get on the bike. Half a rev then nothing. Press the starter switch and hear a popping sound from under the right side cover.  Hit the starter switch again.  Nothing.
Pull the right side cover.  Check all the fuses.  None blown.
OK.  No lights, no indicators, no blown fuses, no nothing.  Kill switch in the run position.  This, says I, looks a lot like a fried starter switch.  Search the phone for likely assistance. WANDERER!  Call Jeff, leave message about needing help field servicing a starter switch.
Proceed to take the switch apart without assistance.  Contacts are greasy and dirty, but absolutely no sign of scorching or arcing.  Scrape 'em clean anyway and reassemble.  Turn the key. Now I've got lights and indicators.  GREAT!  Hit the starter switch.  Pop. Nothing.
Maybe it's the clutch, kickstand, neutral, whatever switches.  Nothing.  Wait awhile. Turn key.  Lights and indicators! Hot cha cha cha!  Push the starter button.  Pop. Nothing.
Jeff calls.  Put him on speaker and run through all the scenarios.  No progress. It's behaving as if there's a circuit breaker popping, then resetting after a few minutes.  Jeff calls Daniel Meyer, then calls me back.  Lots of head scratching over the cellular network.  No luck.
Gent pulls up on a sport bike.  He listens while I run the sequence.  Points to the starter solenoid and says that's where the "pop" comes from. Hmmmm.  He ambles inside for a haircut saying he'll help some more when he comes back.
Call Jeff again.  He still suspects the starter switch, but we're now nosing around the battery connections.  All seem good, but "reset" interval is getting longer.
Decide to try and push start it when my new pal Russ comes back.  Jeff's making multiple offers to come up and help, but Richardson to Lewisville ain't just around the block and I keep telling him to hold off.
I button up everything I've taken apart while waiting for Russ.  He comes back.  I offer to let him do the starting while I do the pushing, but the poor guy won't hear of it, so he gets behind and starts shoving 800 lbs of Valk and my less-than-petite frame through the parking lot.  It doesn't start.  We try again, and get a few sputters of ignition,  but no start.
Now, I think I've got it.  I call a friend to bring his truck, thank Russ and let him travel on, call Jeff and tell him to sit back and have a beer, I won't be needing Wanderer's AAA service this particular evening.
My friend arrives.  We hook up jumper cables to his (non-running) truck, touch them to the Valk's terminals, and it roars to life as soon as I press the starter switch.
Only took two hours to finger out what was wrong:
BAD BATTERY.  BAD, BAD BATTERY.  No warning, no crank and crank and crank and crank without starting, no slow crank.  It went from enough juice to start to not even enough juice to fully energize the starter solenoid.  The only thing I can figure is I had a cell suddenly short.  The circuit breaker-like behavior was a recovery cycle after the starting circuit was draining it completely.
It's only about two years old, spring of '08 I think.  I reckon the heat here uses 'em hard.
Rode home, pulled into the garage and shut it down. Immediately turned the key back to on.  Only dim lights and indicators.
Off to the store tomorrow...
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
godfire
Republic of Texas
« Reply #1 on: January 22, 2010, 08:36:45 PM »
Whoa!
My starter switch went out at Lake Texoma.
Luckily some new found friends gave me a push.
Got her home, fixed the switch, and two days latter she would turn over two to three times and then nothing. Battery voltage was around 11v. New battery and life is good!
Sorry to hear about your troubles....
Ride Safe
Ride Often
Daniel Meyer
Moderator
The State of confusion.
« Reply #2 on: January 23, 2010, 05:56:08 AM »
Glad you got her home!
On these machines, it's often the simple things...
CUAgain,
Daniel Meyer
Valkpilot
Corinth, Texas
« Reply #3 on: January 23, 2010, 06:31:03 AM »
Do you think my diagnosis is correct, O Sage of Many, Especially Electrical and Petcock-Related, Things Valk?
The lack of warning symptoms is a little disconcerting.  This could have been a middle-of-nowhere serious issue.
« Last Edit: January 23, 2010, 06:34:53 AM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Wanderer
The Great Republic of Texas - Dallas
« Reply #4 on: January 23, 2010, 08:56:18 AM »
There is a 25% off coupon on Dallas Honda's Facebook page that looks like it covers batteries, David. You can get your old batt. tested there too.
http://www.facebook.com/photo.php?pid=3260152&id=206371634144
I just installed this Signal Dynamics led on Bill Parish's standard and my (sounds like a two cylinder tractor) GS1200 in an effort to keep the surprises to a minimum, hopefully. Be careful where you mount any of the led line voltage gizzmos. They are sooooo bright! ~Jeff
12 Volt LED Voltage Monitorpowered by Aeva
« Last Edit: January 23, 2010, 10:42:55 AM by Wanderer » Logged
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
Daniel Meyer
Moderator
« Reply #5 on: January 23, 2010, 09:11:23 AM »
Sounds like bad battery or alternator for sure.
Test the battery since you've got 'er home then go from there.
CUAgain,
Daniel Meyer
Valkpilot
Corinth, Texas
« Reply #6 on: January 23, 2010, 10:48:33 AM »
Had the battery tested.  Lot's o' volts, no amps.  New battery procured.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Daniel Meyer
Moderator
« Reply #7 on: January 23, 2010, 02:58:59 PM »
Woot!
CUAgain,
Daniel Meyer
Valkpilot
Corinth, Texas
« Reply #8 on: January 23, 2010, 04:32:20 PM »
Woot, indeed.  Relief to confirm it was something so easy.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Dodis
'98 Blue & Cream
Texas City, TX
« Reply #9 on: January 24, 2010, 10:58:08 AM »
Same happened to me at the '07 Lone Star Rally.
Turn on key, lights and all just fine. Hit the starter button, all goes black. Did a few obvious checks, then used my high-tech helmet lock cable to jump across the battery (lightly), no spark at all. Dead cell...  tickedoff My brother ran to a local auto parts (on his HD  Angry ), got another battery just before they closed, all has been well since...  cooldude
VRCC# 27132
mr_dodis(a)yahoo.com
DS#513 GY-TT 205/60   (still waiting for my cookie!)
Valkpilot
Corinth, Texas
« Reply #10 on: January 24, 2010, 03:09:34 PM »
Exactly the symptoms, it's just that I leaped immediately to more complex probable cause.
You can bet I'll pay a little more attention to starting behavior.  This new battery is the same brand as the other (Xtreme from Batteries Plus), but a step up: 200 vs 130 CCA and twice the warranty.
I carry a lot of stuff to do road-side repair, but I'm not carrying an extra battery!  I may, however, make a set of compact jumper cables to stick in the dark recesses of the right saddlebag.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Valker
Wahoo!!!!
Texas Panhandle
« Reply #11 on: January 24, 2010, 06:44:39 PM »
This dreaded "Pop" from the battery was a fairly common occurrence on GoldWings a few years back (Maybe more than a few). First I've heard of it on ours.
RainMaker
Arlington, TX
« Reply #12 on: January 24, 2010, 07:59:47 PM »
The original battery (Yuasa) went 9 years in my I/S and was still starting it when I decided to change it just because of the age.  I put in another Yuasa and expect it to go another 7 years and match it's predecessor.   Used to get batteries for my previous bikes at Pep Boys and Wally World and they would usually last about a year before needing replacement.  Yuasa is the best, IMHO.
The original 10+ year old battery still holds full charge and is being used to power 12V items on my work bench.....
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Valkpilot
Corinth, Texas
« Reply #13 on: January 24, 2010, 11:36:34 PM »
My original went 10 years too.  We'll see with this new one.  If it gives trouble after only a couple of years, I'll be back to Yuasa too.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
