February 12, 2026, 01:14:06 AM
Valve adjustment go-no-go
Topic: Valve adjustment go-no-go (Read 1778 times)
September 17, 2022, 06:07:33 PM »
intake as example;
is 0.006 go and 0.007 the no-go?,
or is it
0.006 go, 0.007 almost no-go and 0.008 is actually the no-go? this is in shoptalk
which of the above is the correct and best procedure?
thanks
Last Edit: September 18, 2022, 04:12:56 AM by 98valk
Re: Valve adjustment go-no-go
September 17, 2022, 06:59:29 PM »
I don’t do this. I carefully adjust so the .006 and .009 fit properly. Slight drag BOOM done.
September 17, 2022, 07:20:27 PM »
Quote from: Chrisj CMA on September 17, 2022, 06:59:29 PM
that is what I have done in the past, with 0.007 will not fit. However was reading the write up in shoptalk and it does the 0.008.
so wondering which is actually correct or best, etc.
WintrSol
Florissant, MO
September 17, 2022, 08:45:53 PM »
As is said, a tappy valve is a happy valve, so a touch wider won't hurt, and won't affect the peak power that much. Just never go less, ever; you don't want your valves to be too quiet.
That said, .006 and .009 are just half a hair wider than the metric spec values of .15mm(.0059") and .22mm (.0087"), but not enough to matter.
Last Edit: September 17, 2022, 08:52:24 PM by WintrSol
September 18, 2022, 05:54:58 PM »
this time I followed the shop talk go no-go instructions. worked well and faster to do less guess work.
Bagger John - #3785
September 19, 2022, 07:06:04 AM »
+1
