« on: October 01, 2022, 07:22:02 AM » |
I never knew this from all the times I used my drills. I have battled at times releasing the bit but never knew this was the problem or actually the feature that works. I have also had bits release on me when I was using them, but now how awesome is this to lock the bit in place. I was laughing when I saw this and thought I cant be the only one who didnt know this as much as I use the drills. Cordless drills have an unknown feature that seems too good to be true. I reached out to the manufacturers to see if this is real. #powertools #diy #cordlessdrill https://youtu.be/q1QHOKF8NO4
« Reply #1 on: October 01, 2022, 08:05:51 AM » |
Interesting. Will have to see if that really works.
« Reply #2 on: October 01, 2022, 12:40:11 PM » |
Thats how to do it.
« Reply #3 on: October 01, 2022, 04:03:56 PM » |
Thats how to do it.
OH come on you already knew about this?  and you didn't share
Bret SD
San Diego, Ca.
« Reply #4 on: October 01, 2022, 04:31:55 PM » |
Ummm.. I've drilled countless holes while building for over 30 years and never had a bit come loose. What's the big kerfuffle about?
Bret
02 Standard -- Blue & White 82 Aspencade -- Red “No man has the right to be an amateur in the matter of physical training. It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable.” Socrates
Psychotic Bovine
« Reply #5 on: October 01, 2022, 04:39:51 PM » |
"I aim to misbehave."
Psychotic Bovine
« Reply #6 on: October 01, 2022, 04:57:46 PM » |
DIGGER
« Reply #7 on: October 01, 2022, 05:33:57 PM » |
My makita does it. Never heard of it before. Just tried it
« Reply #8 on: October 01, 2022, 06:41:26 PM » |
Lol. I went out to the shop and grabbed my 20V Dewalt. Yes it does it but I’m having a hard time finding any value in this feature. I’ve never had a problem not knowing about this for all these years.
« Reply #9 on: October 02, 2022, 03:43:54 AM » |
Thats how to do it.
OH come on you already knew about this?  and you didn't share  Just selfish I guess.
« Reply #10 on: October 02, 2022, 03:44:47 AM » |
You guys have never had a bit slip !?
« Reply #11 on: October 02, 2022, 05:36:26 AM » |
Sometimes when you are trying to use a small grinder on the drill or a round wood rasp, or even trying to slightly enlarge the hole on a piece of metal I have had the drill come loose. I have also had a hard time releasing the bit not knowing about this feature and not getting the bit to release.
Bret SD
San Diego, Ca.
« Reply #12 on: October 02, 2022, 07:50:57 AM » |
You would think that any counter rotational forces which might happen to loosen the collar would naturally click the chuck back into that backed off, quarter turn position? The only time I've ever had a bit come loose is on a keyed drill chuck, and that didn't happen very often either. This looks like some clever YouTubers have found a way to make a little money. I'm guessing many drill brands use the same third party chuck manufacturer.. Could be wrong on that though. edit: just checked it out on my Milwaukee drill, it does click back.. I guess it's an interesting thing because very few people know about it. In my day-to-day work it makes no difference at all.. Might come in handy during a Trivial Pursuit game.
« Last Edit: October 02, 2022, 07:59:19 AM by Bret SD »
Bret
Grandpot
Fort Mill, South Carolina
« Reply #13 on: October 02, 2022, 08:17:01 AM » |
This one click move in the opposite direction does not actually put any more clamping force on the drill. I haven't taken one of these chucks apart, but I believe this one click is really an intermediate position before the ratchet pawl engages to turn the chuck in the opposite direction. This is not in the manuals because it doesn't serve any useful purpose and cannot be used by marketing as a "feature."
 Experience is recognizing the same mistake every time you make it.
« Reply #14 on: October 03, 2022, 04:57:12 AM » |
That feature is there, but, I don't use very often either. But I have bits slip quite often, just grab the chuck and I tighten it back up. I just thought it was part of making holes.
« Reply #15 on: October 03, 2022, 12:21:56 PM » |
Back Before I joined The Navy-1964-I worked as a production machine operator. On one of the drill presses I used there was a keyless chuck. The drill press stayed running as I changed out drill bits and reamers. Piece mounted to a jig and the jig had different settings for the drills reamers and the taps that were mounted to different drill presses sharing a common table. NOT Really relavent to todays cordless drills but as stated I was using a keyless chuck back in the early 60s! Do NOT Know how far back a keyless chuck goes.  RIDE SAFE.
Moonshot_1
« Reply #16 on: October 03, 2022, 01:05:28 PM » |
Got a cordless drill. (DeWalt)
Had others. This is the first time I've heard about this feature.
I don't use the drill much. Don't use tools much anymore but when I did one of the things I'd use the drill for was to take screws out as I would disassemble something. This is when I would have the bit come loose as it is spinning in a way that would tend to loosen things. Wonder if this feature solves this problem?
Mike Luken
Cherokee, Ia. Former Iowa Patriot Guard Ride Captain
Funbaldguy
« Reply #17 on: October 03, 2022, 03:14:42 PM » |
Well I’m glad you put it out there. I can now say I learned something new today. Honestly should be more general knowledge for everyone who uses a cordless drill. I’m going to be passing it on to my coworkers. Thanks again!!
