February 11, 2026, 09:59:35 PM *
Author Topic: Alternator Bearing Numbers  (Read 1756 times)
bikerboy1951
Grand Forks, ND
« on: October 31, 2022, 08:05:45 PM »
Does anyone have the numbers for the two bearings in the Valkyrie alternator?  Would like to rebuild mine and want to have the bearings before tearing into it.
Thanks.
Brad
« Reply #1 on: October 31, 2022, 08:49:33 PM »
I have only replaced the rear one which usually goes bad. Front normally doesn't.
I used Napa 6000-2RSJ specifically designed for alternator use. It is a SKF bearing
https://www.carid.com/skf/alternator-bearing-mpn-6000-2rsj.html
Napa Echlin brush set ECH E395 are replacement brushes.
« Last Edit: November 01, 2022, 07:12:32 AM by 98valk » Logged
« Reply #2 on: November 01, 2022, 06:01:47 AM »
Thanks.
Brad
Nothing to do with your question but may be of help in the future.
I printed and laminated it and kept in my saddlebag.
http://www.jkozloski.com/generic_parts.htm
This was created quite a while ago so some links may not work.
SCain
Rio Rancho, NM
« Reply #3 on: November 01, 2022, 06:40:54 AM »
Honda Part # 31113-MN5-005 Hitachi Bearing $22.55 from Partzilla, I don't know the actual bearing number, I think I have one at home, I'll take a look tonight and see if it has a number on it.
This is the Rear bearing only.
Steve
