November 20, 2025, 07:32:11 PM *
Author Topic: Troubled Interstate in Ireland  (Read 2045 times)
Paddy
Kerry Ireland
« on: January 25, 2010, 07:19:00 AM »
Greetings from Ireland, Ive had to remove the Fairing from my 99 I/S and now i have no instrument's
is it possible to fit a speedo and neutral light without the fairing? i noted the speedo is read from an electronic something or other at the front wheel,,,, Cheers
« Reply #1 on: January 25, 2010, 07:37:30 AM »
See if I understand this.
You took the fairng off.
You did something in the fairing.
You put the fairing back on an now it no work.
Is this correct?
If so, I'd say you didn't get a connector seated properly.....
Challenger
« Reply #2 on: January 25, 2010, 08:59:16 AM »
It sounds to me like he has removed the farring completely and wants to install standard type guages, I would consider pinwal parts for a cable drive and speedo.
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: January 25, 2010, 11:27:01 AM »
The entire wiring harness would have to be changed to accomodate a removal of your fairing and replacement of the Standard/Tourer gauges, odometer, warning lamps, headlight, and the wiring for the radio speakers.
IMHO
My advise is to keep an I/S as it should be, but it is your bike, so take any advice for what it's worth.
ALWAYS QUESTION AUTHORITY!
Paddy
Kerry Ireland
« Reply #4 on: January 25, 2010, 12:17:50 PM »
Yip Challenger was right in his assumption,, i removed the Fairing well the sudden impact with the Irish roads removed it for me,,, Ouch !!!! the bike is now rebuilt and driving grand, im not going to be able to repair the fairing,, the electrical connector is there for the fairing but what i am trying to do is just fit a single clock (speedometer) all the other electrics are fine like headlights etc
Any help would be appricated
Cheers
9Ball
« Reply #5 on: January 25, 2010, 12:33:14 PM »
time to consider replacing with Dakota Digital unit.  You already have the electronic speed sensor with the I/S.  Should be an EASY MOD.
There's others here that have done this......
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
valkeire
Dublin, Ireland
« Reply #6 on: January 25, 2010, 03:39:01 PM »
Hi Paddy,
Sorry to hear of your troubles, I'm in Dublin. I've had my Interstate apart several times, if I can be of any help to you let me know.
Regards,
Valkeire
Madmike
Campbell River BC, Canada
« Reply #7 on: January 26, 2010, 10:42:49 AM »
The Interstate speedo is electric, the Standard/Tourer is mechanical.
You can either get an aftermarket electronic speedo or speedo/tach, maybe an aftermarket mechanical drive, or switch the speedo over to the stock Std. model.  Here are the Dakota Digital ones that have been mentioned:  http://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID=560/home_id=-1/mode=cat/cat560.htm
If you decide to use the stock standard model you will need to get a cable, the speedo head and the mounting hardware to fit it to the bike.  Here is the fiche for a '99 Std., it also shows the matching Tachometer - not sure what you would need to do to wire that up but if you check the schematics you can likely figure it out.
http://www.hdlparts.com/fiche_section_detail.asp?section=148152&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3467
Somebody had a speedo head for sale on the classified board a few days ago not sure if it is still available and whether it is KMH or MPH (suspect MPH likely from an American bike imported into Canada).
The KPH ones may not be available from the States.  If you would rather have one in KPH and want to price them here in Canada to see how it compares to your local price then send me a message and I can check price and availability with a phone call.  I bought one about a year ago and got it in a few days from the Honda warehouse in Canada.
