Grandpot
Fort Mill, South Carolina
« on: November 23, 2022, 06:50:40 AM » |
My Lady identified as a Harley this morning. She has an oil leak from the left side of the timing belt cover or from the cylinder head gasket. It's hard to tell until I really clean it up. The leak is only a drop every 10 minutes and only if the engine is running or has just been running. I doubt if it is the cylinder head gasket.
All the bolts on the timing cover are tight.
The timing belt cover hasn't been off in about 3 years. Looking at the parts drawing, the gasket looks like it is split on the left end. It doesn't look continuous like an O-ring. I don't remember. Can anyone verify that for me?
 Experience is recognizing the same mistake every time you make it.
« Reply #1 on: November 23, 2022, 07:13:42 AM » |
You are correct. Anything could happen, but Valkyrie oil leaks are usually the shifter shaft seal.
« Reply #2 on: November 23, 2022, 07:14:16 AM » |
Grandpot
« Reply #3 on: November 23, 2022, 07:36:09 AM » |
Thank you gentlemen. My first thought was the shifter seal, but nothing is that easy for me. This leak is at the front left side of the engine.
« Reply #4 on: November 23, 2022, 07:53:53 AM » |
the last time valve covers were off, the camshaft bearing supports need sealant put in the corners before installing covers. only place in that area that could easily leak oil.
« Reply #5 on: November 23, 2022, 07:57:18 AM » |
It could be the oil seal #22 on the end of the cam. Not a difficult job, just takes time and patience. There's also a small gasket behind the timing belt covers on each side...#6 for the left side. It goes between the cover and the cylinder head. I've had to change both in the past. https://www.servicehonda.com/oemparts/a/hon/506cb666f870023420a41822/cylinder-head
Grandpot
« Reply #6 on: November 24, 2022, 09:02:34 AM » |
The number for the small gasket is actually #7. Regardless of the minor detail, that is where the leak is coming from. Thanks for the tip. Parts on order.
« Reply #7 on: November 24, 2022, 08:16:51 PM » |
The number for the small gasket is actually #7. Regardless of the minor detail, that is where the leak is coming from. Thanks for the tip. Parts on order. Nope, not talking about #7. I'm talking about the small paper type gasket that goes behind the timing belt covers on each side...between that cover and the cylinder head. Couldn't really see a need for it but rather than order one a while back while working on the Wing engine, I simply cut one out of some gasket material. If the leak is coming from the area of #7, then your leak is internal and coming from somewhere else and just showing up in the area of #7.
Grandpot
« Reply #8 on: November 25, 2022, 12:50:03 PM » |
The number for the small gasket is actually #7. Regardless of the minor detail, that is where the leak is coming from. Thanks for the tip. Parts on order. Nope, not talking about #7. I'm talking about the small paper type gasket that goes behind the timing belt covers on each side...between that cover and the cylinder head. Couldn't really see a need for it but rather than order one a while back while working on the Wing engine, I simply cut one out of some gasket material. If the leak is coming from the area of #7, then your leak is internal and coming from somewhere else and just showing up in the area of #7. Thanks for the clarification. I'll look at that for sure. Fortunately I have experience forming paper gaskets.
