November 11, 2025, 06:24:51 PM *
Author Topic: Clutch lever maintenance  (Read 1783 times)
da prez
Wilmot Wi
« on: December 05, 2022, 02:47:59 PM »
  As well as I care for my bike , I must admit I overlooked an item.  I was installing wider levers and found the clutch lever bushing to the master cylinder pushrod was worn out to where the rod was hitting the lever. I installed a new bushing and lubed all moving parts. Clutch lever is so smooth now.
                                       da prez
« Reply #1 on: December 05, 2022, 03:05:53 PM »
I did the same a couple of years ago, changed out the pivot bushing, put on some new
levers I'd had for a long time and replaced the boot... my levers went from floppy to
terrific, like a new bike... a really good cheap upgrade...
« Reply #2 on: December 05, 2022, 04:34:01 PM »
From our own Generic parts (jkozloski) list publication:
 Clutch lever bushing
The Honda part Number 2285-MBO-006 is $10
The Suzuki part number 59892-08A00 is $3 and exactly the same part.
ridingron
Orlando
« Reply #3 on: December 05, 2022, 06:47:44 PM »
  That should be  22885-MBO-006.
« Reply #4 on: December 05, 2022, 07:08:21 PM »
With time and inflation the Honda bushing is at $12.41. The Suzuki bushing is at $4.92
F6Dave
« Reply #5 on: December 06, 2022, 06:02:18 AM »
While you're at it you might want to replace the rubber boot that protects the pushrod and piston. I noticed it was slightly torn on my 6 year old F6B this summer. Then I checked the Valks and they were in much worse condition. They were about $10 at Rocky Mountain ATV. Not surprisingly the GL1800 and Valk use the same boot.
