November 11, 2025, 04:34:25 PM *
Author Topic: Went LED - Lights flicker  (Read 2225 times)
JimF2424
Valkyrie
Gulfport MS
« on: December 17, 2022, 03:27:51 PM »
Just installed LED Headlight and side lights from Eagle Lights.  They work good.   When the bike is running, I get a small flicker which is from the fuel pump.  You can notice it a lot when I first turn the key on, but not as much once it's running.  When running, you can notice it a little.  Does anyone have an ideal how to eliminate it all together.   The fuel pump is connected to the spare connection above the relay which runs from the key switch.
Avanti
Stoughton, Wisconsin
« Reply #1 on: December 17, 2022, 04:41:25 PM »
Do you have a belly tank?
JimF2424
Valkyrie
Gulfport MS
« Reply #2 on: December 18, 2022, 04:02:51 AM »
Yes, I have a belly tank.
Avanti
« Reply #3 on: December 18, 2022, 10:08:11 AM »
I would start by checking the charging system with a test meter. Also verify a good battery along with making sure the system is grounded properly.
« Reply #4 on: December 18, 2022, 11:32:01 AM »
I'm an auto electric idiot, but I've been told that problems with LEDs are very often grounding issues.
JimF2424
Valkyrie
Gulfport MS
« Reply #5 on: December 18, 2022, 03:22:45 PM »
There's nothing wrong with the electrical or fuel pump.   I can unplug the fuel pump and start the bike, it will run for a while without the pump running, I kown that for a fact, because I've gone about two miles before it runs out of gas in the line and floats.   I unplug the pump, start the bike and the lights don't flicker.   Searching you tube and for vehicles they have Anti Flicker Capacitor's,  thinking of buying one and trying it.  There not that expensive.   Still open to feed back.   Thanks.
« Reply #6 on: December 18, 2022, 04:35:47 PM »
Someone correct me if I'm wrong, but I don't believe you need the fuel pump to be running to operate the bike. I was under the impression it was used only to replenish the the main tank when needed, therefore not running all the time. Can someone fill me in on that?
« Reply #7 on: December 18, 2022, 05:06:38 PM »
Some people set them up that way. The normal way (how they were designed) was for them to feed out of the belly tank with the pump running all the time.
« Reply #8 on: December 18, 2022, 09:56:03 PM »
Someone correct me if I'm wrong, but I don't believe you need the fuel pump to be running to operate the bike. I was under the impression it was used only to replenish the main tank when needed, therefore not running all the time. Can someone fill me in on that?
Thanks Rob, I've never had a belly tank so not familiar with the plumbing arrangement. I guess I never needed one, always used my fuel gauge and mileage to let me know when I needed to refuel...along with the condition of my keester after 2+ hours in the saddle.  Wink
« Reply #9 on: December 19, 2022, 07:26:11 AM »
If the flicker occurs while idling, it is probably due to low alternator output at idle.  You could probably increase idle speed, but if the bike runs, why bother?  Perhaps one of our electrical experts could comment on if adding a condenser to the light circuit would help, but I personally wouldn't bother.
JimF2424
Valkyrie
Gulfport MS
« Reply #10 on: December 19, 2022, 08:20:02 AM »
I will be rerouting the fuel pump to run from the battery with a relay.  I think this will solve the problem.
Will post results after the work, maybe this holiday weekend.
Challenger
« Reply #11 on: December 21, 2022, 07:17:03 AM »
I put Auxito LED in my Std. It flickered and the light out put was washed out by 50 feet. Actualy had a car pull over as he thought I was a motor cop. Went back to Sylvania Silver Star.
Pluggy
Vass, NC
« Reply #12 on: December 21, 2022, 12:19:23 PM »
Glad you have a Silver Star to keep on riding. Yours is not the only bike to flicker an LED.  That's a sign the "bulb" is not getting a smooth flow of DC.  Are you using a replacement alternator?  Installed any elctrical accessories?
The Auxito LED works well in my bike.  If you lived close by, we could make some measurements and get to the bottom of this.
Challenger
« Reply #13 on: December 21, 2022, 01:08:08 PM »
Appreciate the offer, but I'm ok with the headlight for now. Have an I/S if need to ride at night. Std has original alt with new brushes and a Bons smart switch thats been on there for 5 years. LEDs in spots are rock steady. All connections were cleaned last winter. Might be the electronic relay in the Bons.
Avanti
« Reply #14 on: December 21, 2022, 02:08:30 PM »
Some of those relays would get corrosion between the solder joints causing shorts.
Pluggy
Vass, NC
« Reply #15 on: December 21, 2022, 02:11:22 PM »
Should you wish to experiment....  Install the headlight LED and put a small charger on the battery.  Turn on the bike without starting the engine.  If the LED is bright and does not flicker, the source of the flicker is likely related to the alternator or rectifier in it.  If, with the engine not running you see the flicker, it is  likely related to a component or connection in the electrical system.
Pluggy
Vass, NC
« Reply #16 on: December 22, 2022, 04:39:23 AM »
Yes, try the capacitor.  The old halogen bulbs, or any bulb with a filament, stores some energy.  The capacitor should store evergy and provide a smoother flow of direct current to the LED.
JimF2424
Valkyrie
Gulfport MS
« Reply #17 on: December 22, 2022, 12:03:51 PM »
Fixed the flickering with a relay.  Worked great.
