March 21, 2026, 07:56:51 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: The Freeze  (Read 7812 times)
« Reply #40 on: December 22, 2022, 03:26:35 PM »
ooh - WE ARE UP TO -3 AFTER GETTING DOWN TO -5 earlier today. Will probably drop to -7 or so tonight...
If you step outside right out of the shower, I doubt you can tell the difference.   Grin angel
Weird here, it's going to hit 56 about 9PM.  But 10 tomorrow nite.
« Reply #41 on: December 22, 2022, 03:52:25 PM »
Currently 13.6 here in The Republic... That graph isn't looking any better...
« Reply #42 on: December 22, 2022, 04:36:14 PM »
Lockheed Martin Armed Forces Bowl in Ft Worth TX kickoff... is 11 degrees.   Shocked
Go Air Force!
Oldfishguy
central Minnesota
« Reply #43 on: December 22, 2022, 04:39:21 PM »
As the local Finns say, “SAU-NA”!
At -10F, when life deals you lemons . . .
« Reply #44 on: December 22, 2022, 05:18:39 PM »
Got this in an email from my homeowner insurance provider.   Good advice contained therein.
Dear Rams,
We are aware of the winter weather impacting many of our members across the country. Thank you for trusting us with your insurance needs. We are here for you with tips and advice to help you prepare your property and vehicle.
Make Sure Your Home Is Ready
Here are some precautions to consider:
· Wrap exposed pipes with insulation sleeves or 2 inches of Underwriters Laboratories (UL)-listed heat tape.
· Caulk cracks and holes in the home's outer walls and foundation. Holes left by cable installation can also leave pipes exposed.
· Clear rain gutters, repair roof leaks, check your roof to make sure it can handle the extra weight of the snow and ice, and cut away tree branches that could fall on a house or neighboring structure.
· Install and test smoke alarms and carbon monoxide detectors with battery backups.
· Consider buying alternative heating resources. All heaters that run on fuel (natural gas, kerosene, butane, oil) should be vented.
 Make Sure Your Vehicle Is Ready
Consider the following to stay safe in a winter storm:
· Stay off the roads if possible. If trapped in your car, stay inside.
· Create an emergency supply kit for your vehicle. Include matches, a windshield scraper, jumper cables, a flashlight, warm clothes, blankets, bottled water, non-perishable snacks, and a bright cloth to tie to the antenna.
· Store a small broom and a small sack of sand in your vehicle for generating traction under wheels and a set of tire chains or traction mats.
 Tools to Help You Prepare
Visit our winter storm advice page for additional tools, checklists, and advice to stay safe during a winter storm. Should you need to file a claim, you can do so online. As always, we stand ready to serve you. Stay safe.
 Thank you
United Services Automobile Association
Edited:  Just remembered how we handled extreme cold when I was a kid, left any cabinet doors open if, there was a water pipe in that area.
« Last Edit: December 22, 2022, 08:04:24 PM by Rams » Logged
Moonshot_1
« Reply #45 on: December 22, 2022, 05:28:15 PM »
"· Store a small broom and a small sack of sand in your vehicle for generating traction under wheels and a set of tire chains or traction mats."
Shoot, if ya go down to Florida to get the sand the rest is a waste of time.
Good Lord I wish I was there.
-13 and the wind is a blowin' here like crazy.
Mike Luken
Cherokee, Ia.
« Reply #46 on: December 22, 2022, 05:50:05 PM »
got it a little better than -13 out, only -3 right now and winds a howling 30+ mph.
Further north you go into MN and WI,  gets tad bit colder and usually snowier.  Keep the -10 below up there please.
coldest/windiest EVER experienced was Devils Lake ND ice fishing about -20 or so below zero and 30+ mph sustained winds for 3 days all day on the ice.  Fish had lockjaw during that cold snap so basically drove 20+ hours in partially near whiteout conditions for nothing.   Crazy sitting in a portable ice shack holding it together whipping back and forth even with ski goggles on my eyelids were freezing shut.
I heard Duluth MN and north of there got 2-3 feet of snow recently.  NO thanks, that is a bit much even for me.
« Last Edit: December 22, 2022, 05:56:26 PM by cookiedough » Logged
« Reply #47 on: December 22, 2022, 06:04:42 PM »
-6 locally. I've never seen cold like this before....
« Reply #48 on: December 22, 2022, 06:09:31 PM »
Do any vehicles have (sticking up) antennas anymore?
DIGGER
« Reply #49 on: December 22, 2022, 08:07:09 PM »
On the Houston Tx 6:00 pm news they said at that time Casper Wyoming had a -75 wind chill going on......manoman
« Reply #50 on: December 22, 2022, 09:07:28 PM »
It is currently colder inside my garage (34.3) than it is inside my garage fridge (34.5)....
« Reply #51 on: December 22, 2022, 09:24:59 PM »
      -5 right now. sposed to git to -8. wind still crankin 21  23 M P H which makes fer some SERIOUS wind chill factors!  Lips Sealed I've already laid out the long johns to sleep in and added another blanket. And a pair of wool socks to keep the old feets warm. Last I looked at my Brothers place up North was -12 and some wind. Again I M O winter sux. RIDE SAFE.
Beardo
Regina, Saskatchewan Canada
« Reply #52 on: December 23, 2022, 04:21:18 AM »
-32C with -44 windchill this morning….last few days it’s been below -50 with the windchill. So this ain’t bad.
This was me in November during hunting season…
It’s all good…we need to get the fishing shack out and now the ice is thick enough to drive on  cooldude
Hope all my southern friends with houses and plumbing and roads and infrastructure (and bodies) that aren’t built for this are getting by ok.
« Last Edit: December 23, 2022, 04:36:15 AM by Beardo » Logged
POPS 57
Motorized Bandit
Motley MN
« Reply #53 on: December 23, 2022, 05:33:32 AM »
Southerners are urged not to travel unless absolutely necessary.
Northerners you will need your big coat.  coolsmiley
signart
Crossville, Tennessee
« Reply #54 on: December 23, 2022, 05:35:30 AM »
-8 now in Crossville, TN.   A lot of rain before the big freeze dropping from 42 to 22 in 1 hour.
If'n you're not drippin the faucets, pour a little windshield washer fluid down your shower-sink traps overnight. They will freeze up before water pipes sometimes crack, easily preventable.
I put the Soobie in the garage and covered the 4x4 one ton front half with a tarp in case I had to get out or help someone. with all the rain we had, if  I let the locks and door jams freeze, I'm stuck. I also went up to the shop and brought a propane bottle/torch to the house in case I have to heat up a lock/padlock to get into a shed or my shop.
Stay warm, stay safe. Merry Christmas!
« Reply #55 on: December 23, 2022, 06:09:08 AM »
Anyone wants to monitor what's going in the "Midlands of SC" here is link to a nearby local weather station.
https://www.wunderground.com/dashboard/pws/KSCPROSP24?cm_ven=localwx_pwsdash
« Reply #56 on: December 23, 2022, 06:14:16 AM »
Hmmm, 65F and calm right now, same for tomorrow. Thats cold enough !
But, possible frost Sunday.
Nobody likes a show off…ooh look at us we’re so warm. Smiley
 Grin Grin ;  Still 65F right now, but, not for much longer.  There is a reason we moved here.  Grin Grin
« Reply #57 on: December 23, 2022, 06:17:22 AM »
Carolyn just got a new bottle of that stuff... that sounds like a great idea. Thanks!
I learned only last year that there's a "summer formula"... don't bother if you have that...
« Reply #58 on: December 23, 2022, 06:17:44 AM »
That's it.
I stepped out onto the upper deck and I've never felt cold like it before. Not even in a walk in freezer.
It of course rained for a short while before the cold arrived so now everything is slightly iced. Nice.
« Reply #59 on: December 23, 2022, 06:31:33 AM »
If your house is connected to a private sewer system, I'd suggest you use the "RV" anti freeze.
« Reply #60 on: December 23, 2022, 07:09:07 AM »
btw, 52*F and rain @ 10am.
Forecast to be 12*F tonight at 10pm.
The ponds and lakes around are just starting to freeze up.
With all this rain and forecast of single digits, I may have to find my skates and stick.
h13man
Indiana NW Central Flatlands
« Reply #61 on: December 23, 2022, 07:23:03 AM »
Well I'm @ -10 and constant 30 mph. wind. Biggest issue is I'm getting snow blown into the garage air via leaks so to speak. Scooped out a small cooler of snow and threw into the wind.  Grin Letting the garage warm up for awhile. Haven't been this bad since 96'. Life on the prairie and I wouldn't trade for anywhere else yet. Hopefully tomorrow will allow me to pull the 4600 tractor out and knock down the drifts. In the mean time "let it blow, let it blow, let it bloooow".
F6Dave
« Reply #62 on: December 23, 2022, 07:45:51 AM »
Early yesterday, Casper, Wyoming hit 42 below zero, the coldest ever recorded for that city. Last night I picked my daughter up at the Denver airport and my truck read -22.
Interestingly, -40F = -40C.
« Reply #63 on: December 23, 2022, 07:48:43 AM »
The wind was a little worse on the way home from InZane, but I'm enjoying
the memories of the 100 degree temperature...
« Reply #64 on: December 23, 2022, 07:50:19 AM »
At what temp does throwing water in the air to make snow work?
« Reply #65 on: December 23, 2022, 07:54:30 AM »
To TRULY freeze it would need to be -42, but the thing you're likely referring to is if you throw boiling water into the air at -14 or below it will  basically turn into steam..
https://www.newsweek.com/cold-weather-throwing-boiling-water-air-burns-1768806
« Reply #66 on: December 23, 2022, 07:55:59 AM »
The only time I looked like that was before I learned to use the snowblower downwind.   Grin
« Reply #67 on: December 23, 2022, 07:57:24 AM »
With the sun behind is very creative.
0leman
Klamath Falls, Or
« Reply #68 on: December 23, 2022, 08:11:28 AM »
Spent 22 plus years in Southern WY.   Remember a number of winters where the wind blew 40 mph for two weeks straight.  Yeah, this was with temps below zero.  Thats why we left the state.
WE here in Southern OR had two weeks straight of temps in single digits and high in upper 20's. Several snow events with about 16 inches of white on the ground.  Power bill showed 9 degrees less average temps form last year for the month.  Man has it changed.  We didn't get below freezing last night and it has been raining for the last two days.  The snow is slowly melting.  Still have enough for a white Christmas.
Keep safe all you in the big bubble of cold.
msb
Agassiz, BC Canada
« Reply #69 on: December 23, 2022, 08:13:13 AM »
lol...my beard looks like that every day !! 2funny
'99 Red  & Black IS
« Reply #70 on: December 23, 2022, 08:45:02 AM »
The rhododendrons by the front door don't like the cold.  Shocked
F6Dave
« Reply #71 on: December 23, 2022, 09:00:12 AM »
That reminds me of the Memorial Day BBQ many VRCC members used to hold at the Blue Swallow in Tucumcari, NM. One year it had been cold and wet at home, but it was 100 when I arrived. A neighbor who rode with me said he couldn't wait to get in his air conditioned room. I said 'no way, I'm going to sit out front and enjoy this heat -- as soon as I get a six pack.'
« Reply #72 on: December 23, 2022, 09:00:55 AM »
Ski slopes where we used to live [ NYS] could make snow above 32F to close to 40F. I guess it has to do with dew point, humidity and 'wet-bulb temp'.
« Reply #73 on: December 23, 2022, 09:10:09 AM »
I sure don’t miss that. Any pics of some harvested deer ? Merry Christmas Jason  cooldude
« Reply #74 on: December 23, 2022, 09:14:26 AM »
    Havin a heat wave a tropical heat wave!  Roll Eyes It are up to -1!  crazy2 Have water and drainage in all 3 sinks. Old house some drafty BUT I'm still here!  coolsmiley And I did NOT wanna come out from under my blankets BUT old time plumbing was DEMANDING some pressure drop.  2funny Workin on my 2nd cup of HOT COFFEE!  cooldude All right y'all south and east-It's a comin and you have lotsa experience to draw upon from others.  Lips Sealed Winter sux.  ick RIDE SAFE.
Beardo
« Reply #75 on: December 23, 2022, 09:21:46 AM »
Same to you. And yes of course I have pics. I know we have lots of hunters on the board but I don’t know if I’ll offend anyone by posting dead animals on here. Will PM you  Grin
« Reply #76 on: December 23, 2022, 09:35:17 AM »
That's it.
Just remember - real NC residents don't go anywhere after an ice storm Smiley .
« Reply #77 on: December 23, 2022, 09:38:56 AM »
We just got home from appointments with the eye clinic / ordering new glasses / lenses. It was -6F when we left, 1F when we started for home. Unfortunately, after lunch I need to take MIL her new phone.
« Reply #78 on: December 23, 2022, 09:51:09 AM »
Parked the wife's Ridgeline yesterday, it won't even get started till this blows over.   Everything I have with a motor is parked inside (except the Kubota tractor); they'll all stay there until it warms up.
That is all I have to say.
« Last Edit: December 23, 2022, 10:30:44 AM by Rams » Logged
« Reply #79 on: December 23, 2022, 10:13:09 AM »
Just heard about this on the radio and found the link below.
Rolling power outages in TN are coming soon.
NOXVILLE, Tenn. (WATE) – Rolling blackouts began Friday for parts of East Tennessee, per power companies, as the Tennessee Valley Authority experienced high demand for electricity. Please see this story about the updates on the rolling blackouts.
Earlier, some power outages have been reported in East Tennessee as winter weather moves through the region. The region is expected to experience possible flash freezing, single-digit temperatures, and strong winds, which could lead to potential power outages. WATE 6 On Your Side is monitoring power agencies’ updates as they’re made available.
I have also heard reports that several coal fired power stations are down or not in service in TN.  Have not looked it up.
https://www.wate.com/news/top-stories/winter-weather-east-tennessee-power-outages/
Pages: 1 [2] 3 4   Go Up
