April 28, 2026, 08:50:57 AM *
Author Topic: The freeze  (Read 4122 times)
DIGGER
« on: December 21, 2022, 05:46:29 AM »
Well...good luck all you Texans during this freeze.   Bundle up and prepare....could be bad.   A lot of folks are gonna suffer a lot of destruction from busted water pipes.   Get prepared!!!    Good luck all.
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #1 on: December 21, 2022, 07:28:34 AM »
Yeah, we're gonna need a little luck!
I just read that the Electric Reliability Council of Texas (ERCOT) stated, "Electricity supply should keep up with the expected surge in demand."  They also stated, "Changes to Texas’ power grid have improved [our] ability to keep power flowing during extreme weather, but in an extreme scenario, the grid could still face rolling blackouts or tight conditions."
Doesn't really instill a lot of confidence, does it?crazy2
Last time we were totally unprepared, so we had to improvise.  We started by melting snow by the fireplace to flush toilets.  Cell phone service was knocked out, but I happened to have a battery operated radio with some charge left to get emergency weather reports.  Eventually, I dug my truck out of the snow and I made my way over to my shop to tow a 20kW generator home.  Luckily that little generator was full of fuel.  I hooked it into my home's system and we were set.  (FYI, I have no clue how to drive in the snow, but the computer on my 4X4 Tundra surely does!)
We still didn't have any water,  so we continued to use melted snow to flush the toilets.  For potable water we gathered every container we had and I made my way over to my business partner's house who lives near a hospital.  He had water and electricity!  Was able to share some of that water with my neighbor, too.  Later, my business partner's water went off, so I was able to share back some of the water I got from him a few days earlier.  Our water was back by then.
Even though this arctic blast won't have any snow and won't be as severe or cold as the last one, we won't be caught unprepared.  I'm gonna have the generator ready to go (with an extra 20 hrs of fuel on standby).  We're also gonna fill one of our bathtubs with water (for toilet flushing).   I have extra wood already stacked up for the fireplace, extra bottled water and the pantry is stocked full.
With a little luck, we won't need any of that stuff! cooldude
DIGGER
« Reply #2 on: December 21, 2022, 02:06:42 PM »
Sounds like you are ready....bring it on
rocketray
« Reply #3 on: December 23, 2022, 03:47:22 PM »
a smaller gas powered generator --2600 watt is very useful-
Tx Bohemian
Victoria, Tx
« Reply #4 on: December 24, 2022, 05:40:23 AM »
Yea, the freeze a couple of years ago taught us a lesson too!
After Harvey, a few years before, my fabulous SIL, owns an electric company, sent his guys over to install a transfer switch for the generator.
That worked out great during the freeze except my generator was only 5500 watts and could not run the house electric central heater (I bought a 15,000 watt since). We live "out of city limits" so this generator needed to run the water well along with the normal house stuff.
However, my other daughter who lives in town had sewer problems (city sewer system froze) so her and the two grandsons (hubby was stuck at work) came to stay with us and brought over their generator, so we ran a couple room heaters off that one.
It worked well. Nothing I'd want to do forever but given the situation...
One annoying issue is we had "rolling blackouts" with no indication when the grid was going to be off so all of a sudden everything would turn off, so out I'd go cranking up the generators and running outside every hour or so to check the meter to see if it came back on!
One morning I got up and went outside to see if the grid was on, and it was so I flipped the switch, cut the generators off and went inside to make coffee just to have the electricity GO OFF AGAIN as soon as I stepped in the house and got out of my warm coats and stuff!!!  Out I go again!!!
(I need a lite of some kind on that service that I can see from the window instead of dressing up just to go out to see if it's on! Need to hit the SIL up about that...)
This time around, although it's not near as bad, so far we seem to be prepped well (fingers crossed)!!!
Al
