September 23, 2025, 11:30:07 AM *
Author Topic: Compression  (Read 1507 times)
Grey wolf oz
« on: January 08, 2023, 01:25:58 AM »
For the long runners,,,
I am at what is probably about 50k miles
No where near issues,
However i was curious as to where if ever compression issue show up on the valk 1500 motor
Cheers
Luke
« Reply #1 on: January 08, 2023, 07:37:04 AM »
Compression issues should not show up unless there is a problem, like a defective head gasket, cam timing issue or bent broken valve(s), worn or cracked piston rings, scored cylinder bores, casting defect (porosity, cracks), loose/damaged spark plug(s) or any other condition that results in incomplete sealing of the combustion chamber.  I wouldn't try to assign a mileage to compression loss other than high, unless their is damage to the engine.
Usually compression is used to help diagnose performance issues or engine condition.
Grey wolf oz
« Reply #2 on: January 08, 2023, 11:49:26 PM »
Thanks,,
