November 11, 2025, 04:32:41 PM *
Author Topic: Inside of Interstate Fuel Tank  (Read 2342 times)
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« on: January 11, 2023, 03:42:39 PM »
I have an interesting question.
Does anyone here have "pictures" of the inside of our tanks.  I had my tank sealed a few years ago and now that I'm ready to have it painted I have found out the vent is plugged.
I would like to know what the path (how many bends) and where it ends.  The tank was sealed with the red seal and I have learned that Acetone will eat the sealing material so hoping I can unplug.
I know I can buy a vented fuel cap, but really looking to stay with original keyed fuel cap.
Thanks in advance.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #1 on: January 11, 2023, 06:33:45 PM »
Use some wire like safety wire and run up through the tube from the back to the front. As I recall not much in the way of bends, maybe double the wire over so it's larger to make a bigger hole.
Jims99
Ormond Beach Fl.
« Reply #2 on: January 12, 2023, 04:57:09 AM »
Guitar strings work very well for this type of stuff. cooldude
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: January 12, 2023, 02:07:22 PM »
Metal coat hanger, vent tube goes up to the top of the tank back to front along the “spine” and terminates near the fill. Cut coat hanger and pre bend to allow it to slide up easier, cut tip on a diagonal to act as a sharp point. If you can get your hands on a bore scope you can see inside the tank, you might be able to rent one for free from an auto parts store. If it’s an interstate tank you can look through the fuel level sensor opening under the tank
« Last Edit: January 12, 2023, 02:09:11 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
« Reply #4 on: January 12, 2023, 06:22:34 PM »
You can buy endoscope cameras for about $20 on Amazon that plug into your phone or computer.
https://www.amazon.com/Seesi-Endoscope-Waterproof-Inspection-Semi-Rigid/dp/B07PBF6DX5/ref=sr_1_5?crid=1HY18EWPDVZQY&keywords=endoscope+camera+with+light&qid=1673576514&sprefix=endo%2Caps%2C115&sr=8-5
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: January 13, 2023, 07:14:14 AM »
Thanks for the information.  Tank vent now open and ready for paint.
Michael
da prez
Wilmot Wi
« Reply #6 on: January 23, 2023, 11:02:10 AM »
F Y I  . Old speedometer cables or clutch or speedo cables make very good flexible drill bits. I have used this method for many years.  Drill in the opposite direction of the wrap.  I have several in my stash.
                                       da prez
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #7 on: January 25, 2023, 04:36:56 PM »
                                       da prez
Thanks Ross
« Reply #8 on: January 25, 2023, 07:08:39 PM »
not a honda tank but should be similar
https://forums.ninja250.org/uploads/801275.jpg
