Valkpilot
What does the data say?
Corinth, Texas
« Reply #40 on: February 04, 2010, 03:48:29 AM » |
Daughter has UIL Saturday, how late do you think you will be hanging about before you ride out/
I reckon we will be working until at least 1:00 pm.
Valkpilot
Corinth, Texas
« Reply #41 on: February 04, 2010, 03:54:59 AM » |
Hey Dave, would like to check out the wrench party if I have afew hrs. sat. I have some flapper wheels for polishing your intakes if anyone wants some/ if you ever need to replace the intake orings.One of mine was leaking alittle so I replaced them and polished out the intakes.Gets better mileage and way way faster!! Not....but was a pretty neat project since they were off anyway....=They are really rough castings like it says in shop talk..plus and you can see the glass packs I did again!! If I can get over Ill bring a bag of the flappers.Paul Haslet TX.
Address e-mailed to you through your profile. Also sent by Forum private message. Profile e-mail a no-go, it was bounced back to me.
« Last Edit: February 04, 2010, 09:39:56 AM by Valkpilot »
Doc809
« Reply #42 on: February 04, 2010, 05:58:54 AM » |
Joe and I will both be there. Need to replace the petcock, vacuum lines, vacuum caps on his bike, vacuum caps on mine. I have the petcock/screen, 5/32 vacuum line and 1/8 caps. Just need the great wisdom of our VRCC brothers to show me how to do this. L
How much fun can I have before I have to go to hell?
Six Guns
« Reply #43 on: February 04, 2010, 07:14:23 AM » |
I was suppose to be off this Saturday, but another supervisor just put in for vacation at the last minute and they want me to cover for him this Saturday. They are not giving me an option, so I'll have to miss the wrench party. I have had to miss quite a few of the W/P because of work and it's starting to get old real quick. Maybe next time. Keep the sync guages handy.
« Last Edit: February 04, 2010, 09:00:28 AM by Six Guns »
SideCar
Bikers don't need shrinks!
Colleyville, TX
« Reply #44 on: February 04, 2010, 07:23:12 AM » |
Going to try and swing by for a little while to hang out.
Disco
Republic of Texas
« Reply #45 on: February 04, 2010, 01:02:06 PM » |
Notes to everyone who intends to work on petcock/screen, air filter, vacuum lines: It's much easier to remove a fuel tank that is hovering near reserve than one that was topped off on the way to the party.  It's also nice to have a soft towel to set the tank on while it or it's host is being serviced.
2000 Bumblebee Tourer, 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K, 07 Helix 71 MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #46 on: February 04, 2010, 03:59:19 PM » |
Can the pair valve hoses be changed without pulling the air box? Chirp, chirp, chirp!
Disco
Republic of Texas
« Reply #47 on: February 04, 2010, 06:18:49 PM » |
Chuck,
I've only been through this once, but I suspect removing and replacing the air box is not as difficult as doing the pair valve vacuum lines without removing the air box.
The pointers Patron gave me for making the air box portion as painless as possible are 1) when you loosen the clamps on the tops of the carbs, place the clamps above their normal location on the boot and tighten them just enough to keep them from falling off the boots when you don't want them to, and 2) to make replacing the boots on top of the carbs as easy as possible, apply a light smear of silicone grease to the inside of the boot.
Hope this helps,
DFG
godfire
Republic of Texas
« Reply #48 on: February 04, 2010, 06:47:37 PM » |
Can the pair valve hoses be changed without pulling the air box? Chirp, chirp, chirp! Yes, it is possible; however, it is much easier if you pull the air box.
Ride Safe Ride Often
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #49 on: February 05, 2010, 05:20:31 AM » |
Any last minute wish list for parts or tools ... better speak up now! I think I've still got some space in one bag so I could bring a couple of more things (If I've got it and you need it).
Tom
Houdini
Allen, TX
« Reply #50 on: February 05, 2010, 09:24:41 AM » |
I've had the airbox off a couple of times already. The easiest way I have found to get it back on is to warm the tubes with a heater and then wrap a string tightly around all of the air tubes and tie them as scrunched up as possible. The airbox will fit back into the frame much easier and then just cut the string and start fighting the tubes back into place.
I tied strings onto the pair valve vacuum hoses where they connect to the manifolds and pulled the hoses out of the top of the frame. I then tied the strings to the new hoses and gently pulled them back down the same way they came out. It was pretty easy to do. The entire job was made easier by stopping by Harbor Freight and buying two 10" hemostat's on the way home last night. The hemostats were the only way I could change the left front vacuum cap.
My petcock appeared fine and I could find no visible damage to the diaphragm but I know it had issues since it wouldn't hold a vacuum when Charles was adjusting the carb’s a few months back. The hardest part here was getting the filter tube out of the tank; it was stuck pretty good and required working some pliers in enough to get a grip on it. After I get done mounting some LED’s and routing the wires she’ll start going back together tonight.
I can't imagine doing all of this work in the confines of a wrench party but maybe having extra hands would make it all happen much faster.
« Last Edit: February 05, 2010, 11:57:04 AM by Vermithrax »
Disco
Republic of Texas
« Reply #51 on: February 05, 2010, 10:03:00 AM » |
If Frisco is on the way for anyone, BnB Tom and I are going to meet at the Market Street grocery store (NW quadrant of Eldorado & Tollway) at 7:00am. They have breakfast sandwiches, mean burritos, and a coffee bar with baked goodies.
Houdini
Allen, TX
« Reply #52 on: February 06, 2010, 01:55:04 PM » |
OK guys, I have my tank back on but when I turn the gas valve to on my petcock starts to leak gas. I put the diaphragm kit together in reverse of taking the old one apart so I'm pretty sure it is in the correct order but something is obviously wrong. Any suggestion or ideas what to look for?
SideCar
Colleyville, TX
« Reply #53 on: February 06, 2010, 02:29:04 PM » |
Thanks for hosting the wrenches, David. Good to see everyone there. Hoping Joe got a few more MPG on the way home to the baby.
Valkpilot
Corinth, Texas
« Reply #54 on: February 06, 2010, 03:22:13 PM » |
My understanding is that there is one part, perhaps the diaphram, that you can get in backwards really, Really,REALLY easy and that is no better than a busted diaphram.
Houdini
Allen, TX
« Reply #55 on: February 07, 2010, 08:17:45 PM » |
OK, I figured out what I did wrong with my petcock;  I had all of the rubber pieces in the correct order but the seal wouldn't contact the body of the petcock. The first person that posts what I did wrong wins the right to point and laugh the next time we're together.
Ghillie
« Reply #56 on: February 07, 2010, 09:26:17 PM » |
you have to be really careful to seat the diaphragm, jim and dave did the same thing when we did one at my place, bit of a nib that had to be pushed in
When the people fear government, there is tyranny. When government fears the people, there is liberty.
Houdini
Allen, TX
« Reply #57 on: February 08, 2010, 08:29:05 AM » |
bit of a nib that had to be pushed in Close enough; we have a winner!
RainMaker
Arlington, TX
« Reply #58 on: February 08, 2010, 09:38:09 AM » |
Improperly installed diaphragms have been causing problems for years....
 2005 BMW R1200 GS 2000 Valkyrie Interstate 1998 Valkyrie Tourer 1981 GL1100I GoldWing 1972 CB500K1
