March 21, 2026, 03:05:41 PM
Tire size !!! Asking for a friend
Topic: Tire size !!! Asking for a friend (Read 954 times)
larue
Clermont,FL
March 03, 2023, 05:17:37 PM »
This is a non valk question: Can you put 150/70/18 instead of 160/60/18
Thank you in advance
Last Edit: March 03, 2023, 07:02:44 PM by larue
Re: Tire size !!! Asking for a friend
March 03, 2023, 06:11:35 PM »
Quote from: larue on March 03, 2023, 05:17:37 PM
This is a non valk question: Can you put 150/70/18 instead of 160/60/60
Tire Width. 150 vs 160
Aspect ratio. 70 vs 60
Wheel Diameter. 18 vs 60 Interesting.
https://www.lesschwab.com/article/tire-size-explained-reading-the-sidewall.html
larue
Clermont,FL
March 03, 2023, 07:03:29 PM »
Sorry it’s 160/60/18
Brain fart. I apologize
March 03, 2023, 07:07:20 PM »
No problem and I am nowhere near an expert but....
If the tire width is less that would affect the aspect ration it would seem. So...... it would seem it might work...
I have never tried to do that. so.....
Ken aka Oil Burner
Mendon, MA
March 03, 2023, 07:27:42 PM »
This is a good site to compare tire sizes on pretty much anything.
https://www.tacomaworld.com/tirecalc?tires=150-70r18-160-60r18
So, this will give you measurement differences, but it would depend on the bike as to whether it would fit or not.
https://www.amsoil.com/?zo=5889580
larue
Clermont,FL
March 04, 2023, 07:48:25 PM »
Thank you
cagrote
Chinook, WA
Reply #6 on:
March 05, 2023, 04:26:00 PM »
Width changes breaking abilities. The wider the tire the more braking surface you have. You shouldn't go narrower than stock. Wider if it fits is ok. Changing the rolling circumference of the tire will affect handling, braking and weight capacity.
Texan born and bred
