September 23, 2025, 10:45:32 AM *
Author Topic: replacement brake lines  (Read 1596 times)
Swinborg
« on: April 01, 2023, 02:05:30 AM »
Morning Fellas!
Hope everyone  is doing fine!
I am planning on the front end rebuild - so as always started on fork oil swop which of course means taking the brakes off, which of course means replacing brake lines.  Does anyone have experience on SS braided lines?
Was thinking something along the lines (ha!) of this?
https://www.goodridge.co.uk/products/motorcycle-brake-kit-for-honda-f6c-gl1500cv-cw-valkyrie-96-03
steveB (VRCC UK)
« Reply #1 on: April 01, 2023, 02:51:07 AM »
In the UK go to https://www.helperformance.com Next day delivery, variety of finishes and custom lengths and bends if needed. I've fitted loads of them never a problem.
« Reply #2 on: April 01, 2023, 04:53:58 AM »
That makes no sense. The calipers dismount from the fork and you don’t need to disconnect the hydraulic lines unless you just want to.
h13man
Indiana NW Central Flatlands
« Reply #3 on: April 01, 2023, 06:31:25 AM »
Honestly I would stay with OEM lines and yes I zip tie my calipers to the frame when servicing the front. I'm sure you know the condition/mileage/care your bike receives better than I. I like the Valk as it was designed and looks from the factory. I get way too many compliments the way she is though I would like a non metallic paint but with same factory lay out.
« Reply #4 on: April 01, 2023, 07:33:20 AM »
The point here is to NOT just let the calipers hang on the hydraulic lines during your front end service work (however long or much) (that might just age them more than you want).  I use a bent wire coat hanger.
One of my Interstates came with replacement braided stainless front brake lines (and a different brake block (junction) underneath the triple tree, I suppose to better match with the lines).   At 108K miles, I've had no problems.  They don't look like new anymore.  (Some years later I added a matching braided rear hydraulic line, but it's short and barely visible.  I cannot remember the maker.)
My other Interstate with OE lines only has 58K, and I've never had problems with those hydraulics either.  Those look almost new.   Smiley
Both bikes with good (OE) pads and regular clean fluid stop as hard as you could ever want (including lock up), and I can tell no difference between the two (OE vs stainless lines in front;  for 80% of your stopping power).
RonW
Newport Beach
« Reply #5 on: April 01, 2023, 01:00:08 PM »
"The point here is to NOT just let the calipers hang on the hydraulic lines during your front end service. .... I use a bent wire coat hanger."
I use solid electrical wires. And this is one of the reasons I don't let the dealership service the Valk. Even if I tied a loop of electrical wire on the fork within easy reach, I bet the dealership wouldn't use it hang the brake lines.
2000 Valkyrie Tourer
Bagger John - #3785
« Reply #6 on: April 01, 2023, 05:23:34 PM »
I have a couple wood blocks that were made for this purpose. I've also used wire to tie them out of the way.
Agreed re: dealership "skills". One more reason why I encourage everyone I can to learn to do their own.
