November 18, 2025, 08:15:29 PM *
Author Topic: Exhaust blueing  (Read 4576 times)
chickenman
« on: March 08, 2009, 07:43:10 PM »
On the valk tourer what can cause the # 3 and 5 exhaust pipes to blue and the others don't. What is good to get the blue off the pipes?? Thanks!!!
Rider89
VERY Northern Illinois
« Reply #1 on: March 08, 2009, 08:07:08 PM »
my .02 would be the carbs aren't adjusted properly then you could be running too lean.
Also, opening the throttle when the choke open excessively would also cause blueing, and excessive idling can casue it.
I've had some success with Blue Away and Blue Job. I'm sure some people have more experience than me, but good luck.
Markus
Rider89
« Reply #2 on: March 09, 2009, 12:23:31 PM »
Assuming you have the stock pipes, do concentrate on the cause first as it takes a lot of heat to blue the double wall pipes. Are there any signs of problems while riding? I would check the plugs to see how they look now. Burnt valves would be a bummer heading into the riding season.
Big IV
Iron Station, NC 28080
« Reply #3 on: March 09, 2009, 05:53:53 PM »
Sitting around idling needlessly is a main cause of bluing.
"Ride Free Citizen!"
VRCCDS0176
