September 23, 2025, 10:44:49 AM *
Author Topic: Cut of valve testing  (Read 1518 times)
Kgkeates
« on: April 10, 2023, 01:50:31 PM »
Hi all got no1 carb stripped down took off cutof valve found metal piece in carb under cut of valve it was loose so pulled it out its got an o seal top and bottem.  Also a larger o ring in port on cut off valve.  Guesting is this normal on a 2000 valkyrie.  Also how do you test cut off valve can't find any details only that you use a vacume pump.
Avanti
Stoughton, Wisconsin
« Reply #1 on: April 10, 2023, 02:08:13 PM »
Look here. Air cut off valve. Second post.
https://www.southbayriders.com/forums/threads/101750/page-9
Kgkeates
« Reply #2 on: April 10, 2023, 11:20:44 PM »
Thank you very helpfull
