November 11, 2025, 02:40:35 PM *
Author Topic: Air panel installation  (Read 1972 times)
diskmark
Sacramento Ca.
« on: April 17, 2023, 01:32:23 PM »
Hi
I just pulled my carbs to send out for service.
I noticed I do not have an air panel on my 97.
Does anyone have a picture of one installed?
I found one on Ebay, I just need to see the orientation and hardware.
WintrSol
Florissant, MO
« Reply #1 on: April 18, 2023, 09:30:48 AM »
Do you mean parts of the air cleaner assembly? https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/air-cleaner
Or something else in the carb assembly.
Or maybe the air deflector that fits under the radiator? Part #7 here: https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/radiator
diskmark
Sacramento Ca.
« Reply #2 on: April 18, 2023, 10:01:35 AM »
Wintrsol
#5 in that diagram
I don't see any fastening hardware in the diagram
WintrSol
Florissant, MO
« Reply #3 on: April 18, 2023, 11:41:39 AM »
I can't find it anywhere in the service manual, although I think it appears in photos of the thermostat area. Since I haven't had my radiator off, I can't say what holds it in place, if anything. Waiting for one of those who have been into this part of the bike to chime in now.
« Reply #4 on: April 18, 2023, 11:57:34 AM »
There are no fasteners that hold it in place. It is kept there by all the other stuff in its way. They are kind of a pain to get in place. I imagine that’s why it wasn’t put back in.
diskmark
Sacramento Ca.
« Reply #5 on: April 18, 2023, 01:02:53 PM »
Thanks Emperor
I guess that's what I needed to know
« Reply #6 on: April 18, 2023, 06:14:37 PM »
Are you talking about the "air guide plate?'  You need to install it before installing your carbs.
« Reply #7 on: April 29, 2023, 01:59:55 PM »
You can get it in with carbs in place but it’s much harder. Counter to what you think removing the radiator is no help. Remove tank and air box and work it in from the top.
Avanti
Stoughton, Wisconsin
« Reply #8 on: April 30, 2023, 08:44:08 AM »
Be advised. In from the top is the no fun way.
« Reply #9 on: May 01, 2023, 07:15:37 AM »
If the carbs are out it's definitely much easier. No need to remove the tank or airbox to install it, but still not a day at the beach. Soften it with a hair dryer or if it's sunny out, leave it exposed on a reflective surface to soften. Then to install the carbs just remove the upper engine hangers, pull back all that's attached to them and the carbs will then have enough room to clear that air dam. Don't worry about the engine dropping out, it's not going anywhere.
diskmark
Sacramento Ca.
« Reply #10 on: May 02, 2023, 01:28:26 PM »
What is the purpose of the panel.
What is it protecting from the wind?
« Reply #11 on: May 02, 2023, 05:19:30 PM »
Well. It keeps the carbs clean and shields heat from the radiator so the fuel in the carbs is cooler. Everyone I know that was too lazy to put it back in eventually changed their mind and put in back in.
« Last Edit: May 04, 2023, 04:28:15 PM by Chrisj CMA » Logged
diskmark
Sacramento Ca.
« Reply #12 on: May 04, 2023, 02:12:13 PM »
Thanks Chris
