February 11, 2026, 08:18:35 PM *
Author Topic: Anyone know the allen key size for this highway peg?  (Read 2025 times)
« on: April 22, 2023, 01:47:17 PM »
The big one in the 90 degree join.
WintrSol
Florissant, MO
« Reply #1 on: April 22, 2023, 01:56:31 PM »
It looks the same as mine, which is 3/8"
« Reply #2 on: April 22, 2023, 02:04:59 PM »
Not metric?
The smaller ones are 4.5 mm.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: April 22, 2023, 03:10:14 PM »
Not metric?
The Honda stuff is metric, but many, if not most, accessories are SAE.
« Reply #4 on: April 22, 2023, 03:27:05 PM »
That is Kuryakyn hardware, and they are (mostly) all SAE.
I just happened to need to snug up my Kuryakyn Hwy peg earlier today (not the same as yours).  Mine mount on the crash bars, and too snug is too tight to pull up from the seat (underway), and too loose and it falls down by itself.
I don't know the size, but it's the second biggest one in my 3/8 drive SAE socket allen set.
Probably 3/8.
Also, remember you can twist that Dually peg up a bit too.
WintrSol
Florissant, MO
« Reply #5 on: April 22, 2023, 08:41:23 PM »
Nearest metric size would be 9.5mm; I don't have one that size. angel
BTW, 4.5mm is just less than 3/16"; does it fit a little loose?
« Last Edit: April 22, 2023, 08:44:44 PM by WintrSol » Logged
-mike-
Germany
« Reply #6 on: April 22, 2023, 11:51:41 PM »
Do yourself a favor and get a proper SAE allen key set.
Just a little loose metric is just too loose. You'll screw up the screw. (Pun intended)
-mike-
h13man
Indiana NW Central Flatlands
« Reply #7 on: April 23, 2023, 05:57:32 AM »
Kuryakyn footwear has been SAE in all my experience. Purchase a set of quality hex key wrenches. You can buy both Metric/SAE twin packs for reasonable $$. Eklind or Baldor are excellent choices.
https://www.amazon.com/Eklind-Ball-Hex-wrench-Combo-22-piece/dp/B000189RGO/ref=asc_df_B000189RGO/?tag=&linkCode=df0&hvadid=310828259700&hvpos=&hvnetw=g&hvrand=17978653844076448267&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9016735&hvtargid=pla-441869621721&ref=&adgrpid=65583250281&th=1
« Reply #8 on: April 23, 2023, 08:09:19 AM »
The consensus being 3/8 inch I bought this set which will arrive Tuesday.
https://www.amazon.com/gp/product/B084V7KS25/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It can go into my right saddlebag along with the other tools and stuff I carry.
My saddlebag metric set can stay in the garage along with my other metrics  Cheesy
« Reply #9 on: April 23, 2023, 08:10:01 AM »
Spins like a top.
« Reply #10 on: April 23, 2023, 08:10:52 AM »
Whilst I have your attention what size Allen bolt do I need for the brake/clutch fluid covers?
« Reply #11 on: April 23, 2023, 12:42:59 PM »
Using the parts fish, see #21  (clutch, but both use the same screws (not bolts).
Says "SCREW, FLAT (4X12) "  Stock is Phillips/JIS heads.  You get one in a hex flathead, but no idea what the hex size will be.
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CA_(99)_VALKYRIE%2c_USA%2c_VIN%23_1HFSC340-XA200001/CLUTCH_MASTER_CYLINDER/4a380688-44e5-4f7d-9a7d-1f19c6a1fb1b/52230c0a-4d31-4e0e-990d-fde2104bda7b/y
Take one of your screws to a good hardware store.
« Reply #12 on: April 23, 2023, 06:49:22 PM »
Yep , my local ACE will be getting a visit,
« Reply #13 on: April 26, 2023, 06:42:31 PM »
Well made allen keys and a sturdy plastic box to hold them.
