November 11, 2025, 02:40:48 PM *
Author Topic: 1999 Interstate - won’t crank, high pitch whine  (Read 2134 times)
Demoniac
« on: April 28, 2023, 07:53:07 AM »
Just got a 99 Interstate and I’ve already got a 98 tourer. So I’ve messed with my router a bit but don’t know much about the interstate, but when you got to crank it he noise from the interstate is WAY higher (like shrill) compared to the tourer. Anybody ran into this before?
da prez
Wilmot Wi
« Reply #1 on: April 28, 2023, 08:16:01 AM »
Is the engine cranking or just a starter whine. If just the starter , you may be hydrolocked. Pull sparkplugs and timing cover center hole and turn with a socket. If gas comes out of the sparkplug holes , you may have hydrolocked.
        da prez
Demoniac
« Reply #2 on: April 28, 2023, 08:29:26 AM »
The engine is spinning, sounds like it is maybe spinning too fast?
Challenger
« Reply #3 on: April 28, 2023, 09:28:18 AM »
I don't understand your terminology,  you said it won't crank yet engine is turning to fast. If engine is turning, but won't start, try swapping battery from your other bike or charge that one up. Weak battery will turn engine but not have enough energy left to fire the coils.
« Last Edit: April 28, 2023, 11:22:21 AM by Challenger » Logged
Ramie
2001 I/S St. Michael MN
« Reply #4 on: April 28, 2023, 09:42:46 AM »
Almost sounds like your starter is spinning but not engaging the starter gear to turn the engine.  Could be the engine hydro locked and starter gear teeth broke off.
ridingron
Orlando
« Reply #5 on: April 30, 2023, 07:36:31 PM »
Have you verify that gas is flowing to the carbs?
Ran out of gas today on my Tourer. After adding the gas, it seemed to spin over very fast until the carbs were filled and it finally fired up. I'm glad I had a good battery. Thinking seriously about a manual tank valve (not vacuum ).
JimC
SE Wisconsin
« Reply #6 on: May 01, 2023, 09:56:51 AM »
You didn't say if you have had this bike running yet?
If not, it sounds like the starter is spinning with no load, that could be BAD.
It usually means no compression, IE, slipped or broken timing belts, broken starter gears from hydra-lock, etc.
Do a compression check before throwing parts at it.
Jim
Jim Callaghan    SE Wisconsin
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
« Reply #7 on: May 02, 2023, 06:13:38 AM »
Engine my be hydrolocked. Pull the starter and look inside at the gears or you can feel the gear with you finger. The one on the left may have the missing teeth, right gear is the starter gear. Turn the engine from the front under the center cover to spin the gears.
The picture shows the gears with the rear engine case removed from a hydrolocked engine.
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
JimC
SE Wisconsin
« Reply #8 on: May 02, 2023, 04:41:22 PM »
COMPRESSION CHECK is much easier than pulling the starter
Jim
