December 28, 2025, 02:57:51 PM
ticking noise
Topic: ticking noise (Read 1963 times)
mbramley
Painesville Ohio
ticking noise
May 01, 2023, 04:09:30 PM »
Long story short I hit the start button without tensioners on the timing belts. I bent the number 5 intake valve. I purchased another head and it sounds really smooth, bike runs well but I can hear a tick. I used a electronic stethoscope and traced it to by the number 2 cylinder. I have adjusted and rechecked the rocker clearance and still ticks. Before I by a head for that side I thought I would ask on here to make sure I couldn't be hearing a vacuum valve or something in that area. The price we pay for brain farts.
Challenger
Re: ticking noise
May 01, 2023, 05:16:39 PM »
I would do a leak down test on that cylinder before I took it off. Are you sure its not the pair valve you hear ticking?
mbramley
Painesville Ohio
Re: ticking noise
May 01, 2023, 06:04:44 PM »
where is the pair valve? I'm trying to find it on the parts page (Partzilla).The tick speeds and slows with the rpm if that helps.
Avanti
Stoughton, Wisconsin
Re: ticking noise
May 01, 2023, 06:08:18 PM »
On top of the engine underneath the carburetors.
Re: ticking noise
May 01, 2023, 06:51:57 PM »
I doubt it’s the pair valve. It doesn’t make the rhythmic sound like clicking lifters do. I’d bet on other bent stuff. But like Challenger said, check the compressions first.
Jims99
Ormond Beach Fl.
Re: ticking noise
May 02, 2023, 05:29:43 AM »
Have you checked for an exhaust leak?
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
mbramley
Painesville Ohio
Re: ticking noise
Reply #6 on:
May 02, 2023, 05:51:40 AM »
Thanks for all the help. I don't know why i didn't think to check compression and leak down. I will check when I get home. It doesn't sound like an exhaust leak but I will check that also tonight.
=> InZane XXV
