November 11, 2025, 02:38:57 PM *
Author Topic: Thermostat Position  (Read 1460 times)
Dave G
Born in the USA July, 1996
La Porte, TX
« on: May 02, 2023, 02:03:42 PM »
Drilled and tapped boss on thermostat housing for temp gauge sensor.  Sensor plug contacts thermostat.  Honda shop manual says thermostat should be installed with small hole toward the rear.  What is the hole for? If I rotate the thermostat the sensor plug will fit. Rotate or do not rotate?
I am proud to be a "Valkyrie Fundamentalist".
turtle254
Livingston,Texas
« Reply #1 on: May 02, 2023, 02:33:44 PM »
To allow some water past the thermostat to get a true reading on the water temperature
« Reply #2 on: May 02, 2023, 06:54:09 PM »
Go ahead and rotate it. The bleed hole position isn’t important when the ‘stat is horizontal. If it were vertical, the hole should be at the top.
Avanti
Stoughton, Wisconsin
« Reply #3 on: May 02, 2023, 07:34:05 PM »
I put a sensor in mine way back. Thermostat will only go in clocked slightly to miss the sensor. Never a problem.
I also as of lately have use the Gates PowerGrip Thermoplastic Hose Clamps which look nice  and work well.
Crusty1
« Reply #4 on: May 02, 2023, 07:55:21 PM »
The small hole is a bleed hole to prevent air pockets from forming under the thermostat.  An air pocket would prevent the thermostat from opening and cause overheating.  In a car where the thermostat is mounted vertically the hole goes to the top.
