Swinborg
« on: May 03, 2023, 11:32:40 AM » |
So today was a shame down ride and something quite strange happened.
I was over taking a car revs where about 3700 rpm speed was about 70mph.
I had the throttle pinned to the stop and it just ran out of puff! Did not accelerate any more. For a very brief moment the oil light also came on and went off.
I pulled over checked for leaks and oil levels - all fine.
I set off again and it was pretty much back to normal - pulled as hard as I would expect it to (I have a Ducatti 900ss which feels about the same performance and looking at 1/4 miles times the valk is a little slower, but similar). So as a subjective test it felt about the same.
So any ideas on why power dropped and engine light came on?
RonW
« Reply #1 on: May 03, 2023, 12:51:18 PM » |
Honda has a rev limiter to prevent the pistons from flying out of the engine. I'm not quite sure on the Valk though. The way it functions is it shuts down the engine or ignition. But when you roll off the throttle the bike comes immediately back to life.
2000 Valkyrie Tourer
« Reply #2 on: May 03, 2023, 01:15:28 PM » |
Oil light coming on indicates loss of oil pressure. You didn't bump the kill switch by chance, or have a loose connection? Also check for kinked or plugged fuel tank vent, it sounds like the fuel delivery was interrupted, but if the bike was in gear and the engine turning over you should have still had oil pressure.
RonW
« Reply #3 on: May 03, 2023, 02:22:57 PM » |
I was going to say if the rev limiter shuts off the ignition there's no oil pressure, but the spinning engine should keep spinning the oil pump from momentum. Or does it?
Find a straight road and in lower gear, keep holding full throttle even after you whine out the gear. (kinda fun actually albeit on my other bike which I did just to verify there's a rev limiter) If the rev limiter kicks in then look at the oil light.
Challenger
« Reply #4 on: May 03, 2023, 03:55:50 PM » |
Your not going to hit the rev limiter at 3700 rpm, nor will hitting the rev limiter cause the oil light to come on. Your loss of power symptoms sound like a fuel flow problem Check your tank vent as suggested or you could need a new cover set in the petcock. Amanual oil pressure gauge is the only way to find out if you actually lost pressure or you have wire harness or sender problem. Interesting problem, please keep us updated on the cure
« Reply #5 on: May 03, 2023, 04:25:14 PM » |
Challenger is probably right. When you have wide open throttle, the vacuum drops. If there’s any flaws in the petcock vacuum system, fuel flow will be interrupted.
RonW
« Reply #6 on: May 03, 2023, 04:28:13 PM » |
A ruptured cover set does exhibit those symptoms (quote) ..... ran out of puff (end quote) when you roll on the throttle hard. Not the oil light though.  Cody at Motorcycle MD suggests to inspect this part of the diaphragm too.
« Last Edit: May 03, 2023, 04:31:02 PM by RonW »
Swinborg
« Reply #7 on: May 03, 2023, 04:32:48 PM » |
Hey Ron!
Hope your doing well!
Thanks for the advice, might I ask where might I find those parts? Have you a diagram or like?
RonW
« Reply #8 on: May 03, 2023, 04:47:52 PM » |
Btw, Max, are you going to make the deadline for the trip? Cover sets are on the oem FUEL TANK page. Oddly they're cheaper than ebay but if you like faster delivery & free delivery, ebay is the way to go.
Swinborg
« Reply #9 on: May 04, 2023, 05:34:57 AM » |
Well it’s getting there….. ….tickets are booked so now it’s just a case of building up the miles on longer trips and seeing what needs to be done to ensure reliability. The trip has been extended a little…. Check out the map! https://maps.app.goo.gl/iBKoAxbm6u6qDBM39?g_st=icI figured better spend the time riding than on a ferry.. Uk, France Belgium Luxembourg Germany Switzerland Andorra Italy Spain & Portugal 10 countries in 2 days!!!! I am not booking hotels just see where the wind takes me and who I meet along the way!!! Europeans tend to take pity on the weary traveler!!!
RonW
« Reply #10 on: May 04, 2023, 06:30:17 AM » |
Awesome!
Jims99
« Reply #11 on: May 05, 2023, 04:44:50 AM » |
What year is your bike? The earlier models have issues with sending unit misread. There’s an upgrade you can do in shop talk to fix. 2 of mine tend to come on for a second or 5 once in awhile. Sometimes cold, sometimes hot. I haven’t bothered fixing because I know it’s ok. I also agree with the others about fuel and petcock issues.
The light at the end of the tunnel, is a train. 99 tourer 00 interstate 97 standard 91 wing 78 trail 70
Valker
Wahoo!!!!
Texas Panhandle
« Reply #12 on: May 05, 2023, 08:55:41 AM » |
That's for the temp light, not the oil pressure light.
Swinborg
« Reply #13 on: May 05, 2023, 03:42:16 PM » |
It’s a 97.
I took apart petcock today, unfortunately the rebuild kit was really dissimilar to the oem one so I cleaned up diaphragm and reinstalled. I tested and seems ok. Opens flow real easy, so it’s a toll road and a speed test tomorrow! Glad I got tank off as I put in a usb charger cable under the tank.
Steel cowboy
Spring Hill, Fl.
« Reply #14 on: May 06, 2023, 05:22:00 AM » |
I have gone with the “none vacuum” model used by Honda. It is a manual petcock and has to be turned on and off. It is a direct replacement to the Valkyrie’s vacuum petcock. You can reinstall the factory chrome shut off knob on it too. I have had it on my bike for over two years with no issues. Since I turn off my fuel every time I turn off the engine.
Honda 95-98 CBR600F3 CBR600 CBR600SE CBR600SJR
2001 black interstate 2003 Jupiter Orange wing
Swinborg
« Reply #15 on: May 06, 2023, 06:55:29 AM » |
Oh that sounds great!
The idea of not having the faulty diaphragms ruining your day!!! Don’t suppose you can point me in the direction of a part number?
Max
« Reply #16 on: May 06, 2023, 08:51:34 AM » |
« Last Edit: May 06, 2023, 09:46:01 AM by Valkorado »
Challenger
« Reply #17 on: May 06, 2023, 09:10:20 AM » |
Max
Honda 16950-MAL-601 PETCOCK ASSY. CBR600 95'-98'
RonW
« Reply #18 on: May 06, 2023, 08:48:18 PM » |
Anybody knows whether the K & L includes a new strainer (inset photo)? On a different thread, somebody stated that the strainer might get damaged when you pull the assembly from the tank.
ridingron
« Reply #19 on: May 06, 2023, 08:56:00 PM » |
I can let you know about the strainer when mine gets here (all ready ordered).
The other thing is, if you run out of gas, you won't kill the battery (creating vacuum) waiting for the carbs to fill back up. Recently BTDT.
ridingron
« Reply #20 on: May 08, 2023, 08:48:00 PM » |
Anybody knows whether the K & L includes a new strainer (inset photo)? On a different thread, somebody stated that the strainer might get damaged when you pull the assembly from the tank.  Mine (K&L) came today. A new plastic strainer (removable) that is 5" tall and the brass standpipe is 3" tall. I haven't removed my Honda valve yet and I don't recall what the Honda lengths are.
« Last Edit: May 10, 2023, 02:22:47 PM by ridingron »
idaida98
« Reply #21 on: May 10, 2023, 01:55:58 PM » |
Bought a ebay petcock 3 yrs ago installed it and it leaked,no responce from the seller.
ridingron
« Reply #22 on: May 10, 2023, 09:45:13 PM » |
Honda has different part numbers for the plastic screen piece (Valk vs. CBR600). When I pull my Valk valve I will try to determine the difference.
Swinborg
« Reply #23 on: May 11, 2023, 05:01:42 AM » |
Interesting to see how you get on!
Have you fitted it yet?
Max
ridingron
« Reply #24 on: May 11, 2023, 04:47:50 PM » |
Max
No, I'm working on an auxiliary tank set up. I'm going to cut into the fuel line just after the main valve. It'll be a week or 2.
