December 28, 2025, 06:43:47 PM *
Author Topic: Is new gaskets needed for checking valves  (Read 1795 times)
Kgkeates
« on: May 04, 2023, 11:54:33 AM »
Can you get away with using old gaskets when checking valve gaps (tappits)
« Reply #1 on: May 04, 2023, 11:56:37 AM »
Yes
Bagger John - #3785
« Reply #2 on: May 04, 2023, 01:32:17 PM »
Depends on how much cracking is present. If they're still pliable and show no signs of embrittlement, yes. If they've begun to harden and crack I'd replace them.
Age and running condition has a LOT to do with this. 12k miles in 2 years at moderate temperatures isn't the same as 12k in the same period of time running excessively warm, or spread across 10 years in an area prone to dry rot.
« Reply #3 on: May 04, 2023, 05:15:04 PM »
No. '98 and 76k miles, gaskets are are still fine. if u see some fine cracks smear some form-a-gasket #2 on them. then ride.
RonW
Newport Beach
« Reply #4 on: May 04, 2023, 11:51:58 PM »
My gaskets were okay. You'll need sealant such as Hondabond, Yamabond or equivalent for the spots below.
The diagram in the manual is unclear where the sealant goes (to me).
Apply sealant at the 4 'inside corners.'
With cam cover removed, squeeze out at rear end of cylinder head gives an indication where sealant is applied.
« Last Edit: May 05, 2023, 01:13:52 AM by RonW » Logged
2000 Valkyrie Tourer
« Reply #5 on: May 07, 2023, 05:12:24 AM »
Back in 2000 or 2001, I bought a set for my first valve check.
Their still sitting on the shelf in the OEM packaging.
Kgkeates
« Reply #6 on: May 14, 2023, 12:03:15 AM »
Just  a big thank you for all your help
